Main leaf
The spring rates are significantly different. However, the metric ton springs have either one or two extra leaves, so whether just the main leaf might be the same is anybody's guess. My guess would not ... probably not the same.
Image Not Found
never have seen a copy of any standard packs, and i am under the understanding there is about 5 different "standard" packs.
but as the links show, both metric tons used the same main leaf, but completely different secondary leafs. so possible the (multiple) standard packs also used this same main leaf
