LED dashlights
Hi, can someone tell me if its hard to install and  also give me a little help on
getting other parts. I'm looking for the rubber stops that go on the bed and the tailgate. I'm also looking for the rear inner fender flares.
Parts are very hard to find. Any help is greatly appreciated. I just went on the sight and do you have to order for the cherokee
     thanks,  Chris
Guess I'm not the only one "going green", lol.  You guys do the Transfer Case selector light and the lights down the side (Check Engine, 4x4, Hi-beam, etc) as well?
If you need a single LED I've got a few left over (like 9 blue ones for the high beam).
The kit comes with the bulbs for shifting indicators like trans and transfer case. Also some for the lighted switches like Power/Comfort switch, rear wiper/washer, foglights.
so, you will have a few leftovers.
I changed this one issue.  I put the LED kit in my XJ and they were great...BUT...the high beams indicator bulb was too bright for me, I'd hit my high beams and got bright blue in my eyes.  It bugged me so much I had to switch that one bulb out forr a regular bulb
my amber LEDS are dimable... works good too.
here's the link
https://www.amazon.com/gp/product/B00A6WTK2G/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
^^ These got pretty crappy reviews.
If you can't adjust the intensity with the existing rheostat, I don't want them. And installing a PWM LED dimmer is not worth effort to me.
here's the link
mine dim perfectly from the factory dimmer. no additional equipment.
