AMC86Kid Posted December 19, 2016 Share Posted December 19, 2016 Is there any way to fix or replace the stick mines does a whole 360 when you turn it Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 20, 2016 Share Posted December 20, 2016 It's a stalk , not a stick . Simply grab the chrome part and pull it out in the direction of the drivers door Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 20, 2016 Author Share Posted December 20, 2016 ok i did that and it did pop right out i will try to clean the mech out and get it to work could you guys tell me what commands does it do 1. turn left signal 2. turn right signal 3. wiper blades (are there 3 different speeds?) 4. when you pull it towards you what does that do? seems like all i can get mine to do is turn both ways and move the wiper blades I'm not sure how to get it to shoot windshield fluid out ? Link to comment Share on other sites More sharing options...
gogmorgo Posted December 20, 2016 Share Posted December 20, 2016 Pulling it towards you switches from low to high beams, like on every single other car out there. I don't know what the non-delay wipers do. If you're picking stalks at a junkyard (they're seriously common, just about every Jeep, AMC, or GM vehicle from the '70's to early '90's will have one that will work), just make sure yours has the correct controls on it. There's a couple different styles of wiper controls and also cruise control buttons on the stalk if the vehicle's equipped. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 20, 2016 Share Posted December 20, 2016 Have you considered downloading or buying a FSM ? There is a lot of good info that will help with some of the problems you've recently posted about . Don't think of me saying this because no one wants to help ( because that's why this forum is here ) , just that it's another great source . Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 20, 2016 Author Share Posted December 20, 2016 whats a FSM? Link to comment Share on other sites More sharing options...
Airborne Janitor Posted December 20, 2016 Share Posted December 20, 2016 Factory service manual. I picked one up on ebay on CD-rom and it comes in PDF searchable format. I even put it on my smartphone in case I ever need it in a pinch. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xjeep+comanche+service+manual.TRS0&_nkw=jeep+comanche+service+manual&_sacat=0 Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 20, 2016 Author Share Posted December 20, 2016 oh ok no all i have is the Haynes manual for my truck and the jeep electrical trouble shooting book Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Share Posted December 21, 2016 black https://www.amazon.com/Dorman-49277-Turn-Signal-Lever/dp/B001QU9NC4/ref=sr_1_1?s=automotive&ie=UTF8&qid=1482334209&sr=1-1&keywords=Dorman+49277+Turn+Signal+Lever chrome https://www.amazon.com/Dorman-HELP-49273-Signal-Lever/dp/B000CO94C4/ref=sr_1_fkmr0_1?s=automotive&ie=UTF8&qid=1482334209&sr=1-1-fkmr0&keywords=Dorman+49277+Turn+Signal+Lever Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 21, 2016 Author Share Posted December 21, 2016 So will those stalks just plug right in and fix my issues or do I have to replace the mech inside the steering colum Link to comment Share on other sites More sharing options...
gogmorgo Posted December 21, 2016 Share Posted December 21, 2016 As long as all the functions work and it's just the stalk falling apart you should be fine. If the stalk's falling apart you need another one anyway. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 21, 2016 Share Posted December 21, 2016 Is there any way to fix or replace the stick mines does a whole 360 when you turn it If your stalk is turning "a whole 360" most likely the multifunction switch that the stalk plugs into is shot. Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 21, 2016 Author Share Posted December 21, 2016 do you just push the chrome part and the washer fluid comes out ? Link to comment Share on other sites More sharing options...
gogmorgo Posted December 22, 2016 Share Posted December 22, 2016 Should be a flat bit at the top that you twist away from you, yeah. It'll also activate the wipers and then do a couple extra sweeps when you let go. The steering column is a GM Saginaw column, which means nothing to you yet, but it and just about everything attached to it is common to a TON of GM vehicles, so there's a lot of resources online to learn about it, what does what, common problems and solutions, and tearing it down to fix them. I'm not saying don't ask questions, because they'll be there with the answers for the next person who searches, but quite a few of the questions you've asked could be more effectively answered by spending ten minutes with Google instead of a couple days of back-and forth. And a tip, if you're wanting results only from this site (and not getting them through the local search feature) you can try adding the term site:comancheclub.com to restrict a Google search to results only from this site. Another tip is that pretty well everything from the doors forward (and a few things behind them) is the same on an MJ as it is on an XJ, so you might sometimes get more results looking at Cherokee info. I usually search for XJ rather than Cherokee because you'll get a bunch of Grand Cherokee and KL stuff you don't want. Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 22, 2016 Author Share Posted December 22, 2016 Good to know thanks Link to comment Share on other sites More sharing options...
