tarmac2dirt Posted November 22, 2016 Share Posted November 22, 2016 Hello, Were or is there a good replacement front fender liner. I've done a search and seems like the crown liners are pretty cheap and thin material. Just going by what some members have said. Is there a source out there I have not found that makes a OEM equivalent or close to it in quality. Thanks Paul Link to comment Share on other sites More sharing options...
Incommando Posted November 22, 2016 Share Posted November 22, 2016 I got them from jeep for my '88 but that has been 6 or 7 years ago Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 22, 2016 Share Posted November 22, 2016 http://teamcherokee.com/front-fender-liner-oem-jeep-cherokee-comanche-1984-1996/ EDIT: I just looked at the fine print on the bottom of the page, it said: Sorry but this item is currently unavailable. Please check back at a later stage. ____________________________________________________________________ That being said, I replaced mine a few years ago with a set from RockAuto. They actually fit quite well and still look fine. You have to look them up using the OEM part numbers 55175008 and 55175009. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 22, 2016 Share Posted November 22, 2016 I was going to say a JY. Most likely, these are factory parts. Aftermarket ones don't always fit properly. (Chinese Replacement Auto Parts) Link to comment Share on other sites More sharing options...
Minuit Posted November 23, 2016 Share Posted November 23, 2016 I got lucky and found a set out of a 1996 XJ in the yard that were still nice and pliable. Not sure if the 97+ are the same, but if they are that would make it easier to find a good set. Apparently several people have reported good or at least decent results with the aftermarket ones too. Link to comment Share on other sites More sharing options...
schardein Posted November 23, 2016 Share Posted November 23, 2016 I bought two sets from Rockauto for my XJ and MJ. They are a different material than original but that isn't an issue to me if they are durable. Also, I recall they were pretty inexpensive. So far I have only installed one, and it wasn't as good a fit as the original. I ended up with a gap where they are supposed to meet the inner edge of the fender flare. It's noticeable at the rear portion of the front wheel well. Maybe the other 3 will be better when I get around to it. But, I think I would look for a good original set at a junkyard if I had that option. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 23, 2016 Share Posted November 23, 2016 Here's what my aftermarket looks like: I've tried pulling it back behind the flare: no luck. It just slide back out. I tried a little heat (not much, I did not want to damage the paint), with similar results. I have just given up. (Sorry for the blur. I took it at night. My phone must have been drinking.) Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 23, 2016 Share Posted November 23, 2016 Hmm. I got mine a RockAuto and they fit all the flare bracket studs very well. All I had to do was punch out a push nut hole that was missing. But that was maybe 10-11 years ago. I guess they have changed vendors. Good luck finding a usable pair in the yard. Link to comment Share on other sites More sharing options...
schardein Posted November 23, 2016 Share Posted November 23, 2016 Hmm. I got mine a RockAuto and they fit all the flare bracket studs very well. All I had to do was punch out a push nut hole that was missing. But that was maybe 10-11 years ago. I guess they have changed vendors. Good luck finding a usable pair in the yard. Agree finding a usable pair can be hit or miss. Many just crumble apart as soon as you touch them. That's why I bought from Rockauto. Mine look like 87MJTIM's above (gap). Since then I've come across a few 95-96 XJs with front fender liners that looked good and were still very pliable, but haven't bothered to pull them. So I think they can still be found if one is patient. Link to comment Share on other sites More sharing options...
tarmac2dirt Posted November 24, 2016 Author Share Posted November 24, 2016 Thanks for the responses, I gave the local jeep dealer a try and found out that there still available. Price is about $63 each plus new hardware. so I guess I have will give them the business after the holidays. Thanks Link to comment Share on other sites More sharing options...
