Kenosha Warrior Posted July 14, 2007 Posted July 14, 2007 ok, today I went out to the mj, stuck the key in the ign and turned it to 'run' I cranked it and all I got was the starter solenoid click. soon as I rolled the key back to the 'lock' position to take it out. My intrument panel lights light up. I hear a relay click, the instrument panel lights light up, click again, they go off. this will happen 3 or 4 times or until I unhook the battery. I'm a good hour away from my warranty card for my crappy-tire battery. Wtf is going on. Last time this happened, I left the battery unhooked for about 15-20 mins, after I put it back on, I heard a relay go 'click,click' then the jeep started. its been unhooked for the last little while and I get the same results. Its almost as if my battery is fubar'ed.
DirtyComanche Posted July 14, 2007 Posted July 14, 2007 You've probably got some parasitic loss... Or the battery is a pile. Which it is.
Pete M Posted July 14, 2007 Posted July 14, 2007 I would thoroughly clean up the connection surfaces at both ends of the battery cables.
Kenosha Warrior Posted July 14, 2007 Author Posted July 14, 2007 arhg, arighty. oh well. I'm looking at a neon for a DD and a CJ for a wheeler. money money where art thou
Kenosha Warrior Posted July 14, 2007 Author Posted July 14, 2007 Its a little more sinister than that. Instrument panel lights, park lights. They turn on when this relay does it clicky thing. I yanked those fuses and the park lights STILL turn on when this relay clicks! the inst panel lights don't turn on. W.T.F is up. Is my headlight switch gone bad?
CWLONGSHOT Posted July 15, 2007 Posted July 15, 2007 Could very well be. One thing is for sure...you have some crossed/shorted wires there!! Start with the suggestions. Clean the batt connections and eliminate that as any lind of problem. Keep them CLEAN & TITE!! CW
MWinland Posted July 15, 2007 Posted July 15, 2007 Mine had the same symptoms. It turned out to be a short at the bottom of the steering column.
carnuck Posted July 18, 2007 Posted July 18, 2007 Bad ground on the block is causing a feedback through all the lights to try to turn the motor over.
