LEAD_NOT_FOLLOW Posted July 12, 2007 Share Posted July 12, 2007 I tried to search, but when I do I get every post in a chronological order from today's date... I'll be sitting at aprox 6" in the rear. What rear brake line are you guys using for that height? I've done a few more things for added articulation in the rear and need something that is plenty long. Prefer to find something off of another vehical instead of dropping the $$ on stainless from RE (or similar). Thats what I did on my other MJ and I'm determined to find an alternative solution for this one... Thanks in advance! Link to comment Share on other sites More sharing options...
Rokhound Posted July 12, 2007 Share Posted July 12, 2007 mid 90's dakota's should work Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 12, 2007 Author Share Posted July 12, 2007 mid 90's dakota's should work Thanks! Any idea of the length? I'm going to assume that the 4x4 version is a tad longer? Link to comment Share on other sites More sharing options...
Rokhound Posted July 12, 2007 Share Posted July 12, 2007 i nothing about it. i just no that is what i was told i think any modle will work. Link to comment Share on other sites More sharing options...
Pete M Posted July 12, 2007 Share Posted July 12, 2007 I don't know if there's a difference between 2wd and 4wd, but say 4wd just in case. :D It's several inches longer than the stock MJ piece. Link to comment Share on other sites More sharing options...
akamcbird Posted July 12, 2007 Share Posted July 12, 2007 try having the ss ones made up here there is a place called AK Rubber the ones i got for the front of me eagle were cheaper than the stock replacements and more than a foot longer with the fittings i wanted, made while i waited. price of ss proly went up in 4 years though Link to comment Share on other sites More sharing options...
Twisty Posted July 12, 2007 Share Posted July 12, 2007 I have a dakota line in the rear. I'm at 6.5" and have PLENTY of line left for droop/flex. :D Link to comment Share on other sites More sharing options...
JOMJ87 Posted July 12, 2007 Share Posted July 12, 2007 I modified my bracket for mine but i am redoing all the lines and putting it back up there but it has been working great and it was free. :brows: Just something you might try. Cole Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 12, 2007 Share Posted July 12, 2007 That Dakota line will be fine for your application. CW Link to comment Share on other sites More sharing options...
carnuck Posted July 18, 2007 Share Posted July 18, 2007 I did the SOA, bypassed the rear level valve and moved the brake line from the frame down the bracket for the valve and I'm using the stock rear brake hose. Link to comment Share on other sites More sharing options...
