Jtrux Posted September 21, 2016 Posted September 21, 2016 I recently replaced the radiator on my 1987 2.5L equipped MJ and the rubber bushings that the radiator sits on were toast. When attempting to remove the bolts that held them in place, I ended up twisting the nuts right out of the rubber bushing, ruining them. Does anyone know if those are still available and where I might find them? Thanks, Josh
sinkrun Posted September 21, 2016 Posted September 21, 2016 http://www.ebay.com/itm/New-Radiator-Mount-Jeep-Cherokee-1987-2001-/231553472340?fits=Model%3ACherokee&hash=item35e9a99754:g:vdkAAOSwENxXl0q3&vxp=mtr
schardein Posted September 21, 2016 Posted September 21, 2016 https://www.rockauto.com/en/catalog/jeep,1991,cherokee,4.0l+l6,1180055,cooling+system,radiator+mount,11583
Guest Posted September 21, 2016 Posted September 21, 2016 I've never seen the rubber mounts for those before. Never knew they were supposed to be there either; every truck I've seen with a 2.5 never had them. Looks like I learned something new today. :cheers:
Jtrux Posted September 21, 2016 Author Posted September 21, 2016 Thanks for the replies but that's actually not what I'm looking for. These are smallish round bushings that support the upper part of the radiator. I'll try to snap a pic of them later.
HOrnbrod Posted September 21, 2016 Posted September 21, 2016 Pretty sure THESE are what you need. They are called a Well nuts, p/n 34201348. The dealer might possibly have them too.
Rockfrog Posted September 22, 2016 Posted September 22, 2016 The Home Depot near me stocks well nuts in various sizes ... Sent from my SGH-I337M using Tapatalk
HOrnbrod Posted September 22, 2016 Posted September 22, 2016 Most definitely, as does Lowes, Ace hardware, etc. If you can find ones that fit in the hole and have the right thread, they will be a lot cheaper too.
Guest Posted October 9, 2016 Posted October 9, 2016 Not intending to leech off a thread, but does anyone have a picture of how these mount on the core support? Every XJ/MJ I've ever seen in the yards with a 2.5 (not too many, mind) didn't have these. I always thought something should go between the mount and the actual support to keep vibrations to a minimum, but I never thought to investigate. The only ones I've seen listed now that I look are the blocky, square ones. Wierd...
