Jackrabbit41 Posted August 21, 2016 Share Posted August 21, 2016 I want to get rid of the raked look. I want my truck level. what spacers are the best? I only need an inch or so. Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 21, 2016 Share Posted August 21, 2016 They're honestly not much (if any) different between brands. I bought RE ones because I can get them easier than other ones, nothing wrong with them (like most RE stuff). I wouldn't be worried as long as they came from any reputable manufacturer. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted August 21, 2016 Share Posted August 21, 2016 Not wanting to hijack but how much on a stock 2wd would be needed to level it out? I can't stand how low the front sits on mine. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 21, 2016 Author Share Posted August 21, 2016 Not wanting to hijack but how much on a stock 2wd would be needed to level it out? I can't stand how low the front sits on mine. I think like 1.5-2.5 or some thing Link to comment Share on other sites More sharing options...
Eagle Posted August 22, 2016 Share Posted August 22, 2016 Not wanting to hijack but how much on a stock 2wd would be needed to level it out? I can't stand how low the front sits on mine. Put jack under front end. Measure from ground to bottom of flare. Jack up truck until it looks like you want it to look. Measure again to bottom of flare. Subtract first measurement from second measurement. That's the spacer you need. I seriously doubt it's 1-1/2 inches or more. My guess is about one inch. Link to comment Share on other sites More sharing options...
yxmj Posted August 22, 2016 Share Posted August 22, 2016 If you only need an inch or so....all obvious jokes aside..... See if you can get your hands on some grand Cherokee V8 coils that might level you out...or in a pinch track down used ZJ XJ MJ coil isolators and stack them up...this will allow you to go up in increments of about 5/8" to get it to the height you want.As for the spacers I have run both store bought urethane and home made steel....both did the job well Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 22, 2016 Author Share Posted August 22, 2016 If you only need an inch or so....all obvious jokes aside..... See if you can get your hands on some grand Cherokee V8 coils that might level you out...or in a pinch track down used ZJ XJ MJ coil isolators and stack them up...this will allow you to go up in increments of about 5/8" to get it to the height you want. As for the spacers I have run both store bought urethane and home made steel....both did the job well I have lift coils so the ZJ ones wouldn't work Link to comment Share on other sites More sharing options...
1989 Eliminator Posted August 22, 2016 Share Posted August 22, 2016 I put the 3 inch coil spacer blocks on the front and longer rear shackles on the back for a higher look. This also gave me the ability to run 31" tires on my 2wd. Link to comment Share on other sites More sharing options...
