EnlistedManche Posted July 14, 2016 Share Posted July 14, 2016 Hey all its about time i get to the SYE i would prefer to go hack and tap at this time to save a little cash and upgrade down the road. Does anyone know if the front drive shaft from a cherokee will reach the rear pinnion on the comanche? i know it will reach on a cherokee but with the longer wheel base i didnt want to risk it. Thank is advance! Link to comment Share on other sites More sharing options...
Pete M Posted July 15, 2016 Share Posted July 15, 2016 MJs have a lot more wheelbase so, no, the XJ shaft won't fit. :thumbsup: Link to comment Share on other sites More sharing options...
EnlistedManche Posted July 15, 2016 Author Share Posted July 15, 2016 thats not what i wanted to hear hahaha but thank you for the reply! Link to comment Share on other sites More sharing options...
mvusse Posted September 1, 2016 Share Posted September 1, 2016 With a SOA Chrysler 8.25" axle I believe I had to have 19" added to a stock front shaft on a lwb Comanche. On a swb, you'd need to add 12", give or take. Link to comment Share on other sites More sharing options...
75sv1 Posted September 1, 2016 Share Posted September 1, 2016 There is a Spicer list of driveshaft and lengths. You would need to measure from the center of the u-joint on the axel to the end of the shaft of the trans or transfer case (if 4wd). Subtract about 3/4 to 1 inch for the yoke adapter that will go one the TC shaft (or trans). Then measure back to 1-1/8 of splines on the transfer case. This is the range of length you can adapt to. The drive shaft will be noted as extended length. I think the front for an XJ is about 32". Subtract 1" from this. This is so, while the shaft needs to slide in and out. Hope this helps. A lot of this varies as to lift and rear end axle type. Link to comment Share on other sites More sharing options...
Zebvance Posted September 1, 2016 Share Posted September 1, 2016 Hey all its about time i get to the SYE i would prefer to go hack and tap at this time to save a little cash and upgrade down the road. Does anyone know if the front drive shaft from a cherokee will reach the rear pinnion on the comanche? i know it will reach on a cherokee but with the longer wheel base i didnt want to risk it. Thank is advance! Why are you wanting a SYE? Link to comment Share on other sites More sharing options...
xjrev10 Posted September 4, 2016 Share Posted September 4, 2016 I think my rear shaft is 42-43" or 42 and some change. HNT with a 8.25 in a SWB truck. Link to comment Share on other sites More sharing options...
