Looking to learn more about my D44
I recently purchased another MJ D44. I was told
its an open diff with 3.55s. I also read that
the "easy" way to tell is that if you spin one
wheel, if the other spins in same direction then
you have Trac-Lok (LSD.) The new axle spins
opposite of each other - as advertised...
...except...
I finally got around to sanding the rust off the
BOM this afternoon and found 605325-14G. When I
ran this number through Spicer I got "3.55 XJ
Metric Ton w/Trac-Lok." Since I never heard of
a MT XJ I am assuming they meant the Mj. Is there
another way to identify if I have an open diff, or
possibly a factory LSD with blown clutch packs?
Part 2 of this question - A D44-LSD would be
ideal for my build so if it does have it, what
are my options? Its a decent axle and I was
hoping not to spend hundreds rebuilding it (or
if I did I would build an LSD anyway.)
"MT" means Metric Ton -- it was the heavy-duty version of the MJ, and that's why it had a D44 rather than a D35.
The Trac-Lok is a clutch-type limited slip. When the clutches wear out, it then acts like an open differential. You can buy rebuild kits for around $60 to $75 (I think -- used to be $50, but I haven't followed the prices). Be sure to use friction modifier in the gear lube or you'll destroy the clutches very quickly.
So the visual difference would mainly be in the
housing itself (one square, one round?) Hopefully,
unless someone specifically removed the OEM LSD,
there is still a good chance that this axle is
already set up and just needs a refresher then?
That'll be good news for a change...
hmm normally theres more colors and dragons if there's LSD. :yes:
but that's actually good information, my only knowledge is with ford axles, in which the "s" clip is normally the give away for LSD. so knowing round vs square is good!
There will be a min max for the trac loc clutch stack.  I don't know what it is.  I think they are pretty crappy and would go with a true trac or locker.  I had one in my tj dana 44 lucky option. It wasn't working so  I rebuilt the clutch pack and set at max tolerance.  Then it started eating up the spider gears and just went with a detroit locker.  Just 33 inch tires, and not rock crawling or any serious off road stuff.  And don't use synthetic lube, it will leak.  I put new axles and seals in mine, all timken, and the synthetic 85 140 came right out the seal.
It is not a disc count, it is a measurement, like 635 to 655 max, thats what it is on a 8.8 explorer.  You shim it next to the steels not next to the friction discs. But the disc friction plate order has to be followed, you don't want the friction in direct contact with the outer or inner ends of the stack.  The shims can be hard to find so I have used 1 worn original one and 1 new one included in the kit to get to the max tolerance.  And soak the friction discs in modifier overnight after you get your measurements.
