Got a question for ya?
jimoshel
When we haul a vehicle we have hooked to the frame, or go around the axle at all 4 corners. Let the suspension do its thing and not make it so rigid. Has worked well for us. Allow the front straps to pull forward and the rears pull backwards. This does not allow movement forward or backwards....we normally set a brake if we can. I also haul tractors like this, only with a chain and binder. Hasn't failed me yet! Hope I have been some help :thumbsup:
When towing a car with a trailer, do you make the car immovable? or do you leave it loose? Have the transmission in gear or nuetral?
Why might you be asking jim? Are you adding another MJ to the comanche farm?
Towing it on the trailer, I assume?
IMHO, you want it attached in a manner that if the trailer is picked up by a giant, turned upside down, and shaken, that the load will not come off.
Put it in gear.  Set any parking brake apparatus.  Straps, chains, bolts, whatever it takes.  I normally use straps.  The big ones, and lots of them.  Some weird things (super soft suspension, deflated tires, round/spherical objects, broken stuff) also do better if you crib/fence them with wooden blocks that are screwed to the deck, along with straps/chains.
