Streetwedg Posted January 10, 2016 Posted January 10, 2016 Does anyone know where I can get the height senser switch for the load leveler system? I have everything else. Just need the switch that mounts on rear axel with rod to the bed.
Streetwedg Posted January 10, 2016 Author Posted January 10, 2016 I'm not looking for the brake Spenser. I'm looking for switch for air shocks leveling system. I have the under hood air compressor,harness, and air shocks. Need the switch that turns on compressor to pump up shocks
Strokermjcomanche Posted January 10, 2016 Posted January 10, 2016 I'm not looking for the brake Spenser. I'm looking for switch for air shocks leveling system. I have the under hood air compressor,harness, and air shocks. Need the switch that turns on compressor to pump up shocks Misread that then I guess , I'll delete my post .
Strokermjcomanche Posted January 10, 2016 Posted January 10, 2016 Would something like this work for you ? http://m.summitracing.com/parts/dfp-er10031?seid=srese1&gclid=CJfqwb_9n8oCFRCNaQodxYUEkw
Eagle Posted January 10, 2016 Posted January 10, 2016 I'm not looking for the brake Spenser. I'm looking for switch for air shocks leveling system. I have the under hood air compressor,harness, and air shocks. Need the switch that turns on compressor to pump up shocks I've been at this for well over 50 years and this is the first time I've ever heard of a switch to control air shock ride height.
johnj92131 Posted January 10, 2016 Posted January 10, 2016 I'm not looking for the brake Spenser. I'm looking for switch for air shocks leveling system. I have the under hood air compressor,harness, and air shocks. Need the switch that turns on compressor to pump up shocks I've been at this for well over 50 years and this is the first time I've ever heard of a switch to control air shock ride height. If you did find a mechanical switch to turn the compressor off and on, how would you keep it from turning the compressor on ever time you hit a bump? Something to think about. Eagle, how to cars with air suspension turn on and off their air systems? The old GMC motorhome had air bags for springs and to level the coach. Remember them? Electro Level I think they were called.
Streetwedg Posted January 10, 2016 Author Posted January 10, 2016 I don't remember if it came on mj's , but it was an option on xj's. Air compressor under hood with hight sensor from rear axel to body. Automatically raised the air shocks when load was put in and lowered when load was removed.
Strokermjcomanche Posted January 10, 2016 Posted January 10, 2016 That's the first I've heard of any factory leveling system on an xj / mj . Sure it wasn't an ad on ? I know GM is known for using a system like that . If you have pictures can you post some up ? If you can't post pictures pm me and I'll post them .
Streetwedg Posted January 10, 2016 Author Posted January 10, 2016 No it was an option from factory. I have everything but the switch. Even came with an accessory kit that contained a hose you could screw on compressor to fill tires, basket balls, or whatever,
johnj92131 Posted January 11, 2016 Posted January 11, 2016 No it was an option from factory. I have everything but the switch. Even came with an accessory kit that contained a hose you could screw on compressor to fill tires, basket balls, or whatever, Very interesting! Are there any part numbers on any of the components you have? I see some kind of a label on the compressor. Can you post what it says? What other parts of the system do you have? Is there a controller or switch inside the XJ? Can you tell us what year/model you got it off of? Or perhaps you purchased it from someone who took it off the XJ? Any information you can provide would be useful. I frequent a number of salvage yards and would be happy to look out for something like this. Thanks
daking Posted January 11, 2016 Posted January 11, 2016 I'm not looking for the brake Spenser. I'm looking for switch for air shocks leveling system. I have the under hood air compressor,harness, and air shocks. Need the switch that turns on compressor to pump up shocks I've been at this for well over 50 years and this is the first time I've ever heard of a switch to control air shock ride height. If you did find a mechanical switch to turn the compressor off and on, how would you keep it from turning the compressor on ever time you hit a bump? Something to think about. Eagle, how to cars with air suspension turn on and off their air systems? The old GMC motorhome had air bags for springs and to level the coach. Remember them? Electro Level I think they were called. Modern systems use a delay. I was looking at a kit for my HD, and I was concerned about the same-thing. The kit I was looking at, had a ~20sec delay before turning on compressor or releasing air from valve. In the end, I just used bags, no auto leveling or on-board air. I may add that in the future. I never knew XJ or MJ even came with factory air shocks. Personally, if I was going to do it. I'd use bags, with "cups" on the bottom. The bags are rigid mounted to the frame, and sit in cups on the axle. That way they don't limit axle travel. If I hauled with my MJ, that's how I would implement.
Streetwedg Posted January 11, 2016 Author Posted January 11, 2016 Trying to load rest of pics, having trouble with photobucket. I'll keep trying
Streetwedg Posted January 11, 2016 Author Posted January 11, 2016 I think it was only available before 87
HOrnbrod Posted January 11, 2016 Posted January 11, 2016 You are correct. 86 and below. Which part number(s) are you looking for? #7?
Strokermjcomanche Posted January 11, 2016 Posted January 11, 2016 Looks like 84-86 cherokee only Edit , Don beat me .
HOrnbrod Posted January 11, 2016 Posted January 11, 2016 Edit , Don beat me. :rotfl2: :rotfl2: This system would have been much more useful in an MJ since they were the real load carriers..................
Streetwedg Posted January 11, 2016 Author Posted January 11, 2016 Yes that's it. #7 is the part I need
Strokermjcomanche Posted January 11, 2016 Posted January 11, 2016 Edit , Don beat me. :rotfl2: :rotfl2: This system would have been much more useful in an MJ since they were the real load carriers.................. I kind of want this now , I don't know why but I do !!
johnj92131 Posted January 11, 2016 Posted January 11, 2016 Found this on the GM load leveling system: It also uses a 10 second delay to adjust the suspension. http://www.underhoodservice.com/servicing-gm-autoride-rear-air-suspension/
Marine1Texas Posted January 11, 2016 Posted January 11, 2016 When you find the part make sure you get 2. They do not last very long. We had one on a 85 Cherokee and it seems to last only a few years then stopped turning pump on. We had to do it from under the hood till one days a semi totaled it out.
HOrnbrod Posted January 11, 2016 Posted January 11, 2016 You are correct. 86 and below. Which part number(s) are you looking for? #7? No joy in finding the #7 sensor switch. Tried every source I know.
64 Cheyenne Posted January 11, 2016 Posted January 11, 2016 :rotfl2: :rotfl2: This system would have been much more useful in an MJ since they were the real load carriers.................. Personally, if I was going to do it. I'd use bags, with "cups" on the bottom. The bags are rigid mounted to the frame, and sit in cups on the axle. That way they don't limit axle travel. If I hauled with my MJ, that's how I would implement. Don, from an engineering standpoint, although I'm not an engineer, just makes sense, I believe this system was sold for the XJ because it would only carry the occasional extra load, the leveling system allowed the soccer mom the extra level of convenience of not having head lights out of aim, drooped rear end etc. The extra "load" was transferred to the "frame" through the air shocks, via the lower shock mount (usually single shear) and the upper shock mount, which isn't really a suspension load bearing area. I have to agree with daking, it would have been sweet if MJs came stock this way.
HOrnbrod Posted January 11, 2016 Posted January 11, 2016 Possibly Ed. This system was only used from 1984-86, the first three years of the XJ's life. This leads me to believe that the system didn't work all that well, or this option wasn't being ordered by enough buyers to justify it's production. Probably a combination of both. It could have even been adapted from an existing aftermarket system. Still, it would be very cool to have.
