JeepFanactic Posted December 31, 2015 Share Posted December 31, 2015 I have a 1987 MJ with the BA10 5 speed 4.0 I6 and I have been looking everywhere for a donor AX-15 with no luck. I have been looking for months. There are tons of XJ's with the AW4. How difficult will it be to swap to a automatic I'll probably find a donor and swap everything over along with the 4wd conversion. Any advice will help. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 1, 2016 Share Posted January 1, 2016 I see lots of AX15s on craigslist. They are usually listed from $300 to $500. Not sure where in VA you are. Link to comment Share on other sites More sharing options...
joester1908 Posted January 1, 2016 Share Posted January 1, 2016 87MJTIM is correct, I see them all day long in the 300-600 range here on the west coast. Have you tried looking on eBay or other online auto part places like carpartwholesale? But to answer your question, you can swap from automatic to manual pretty easily. You will need an automatic computer, because coming out of it there is another harness that goes to a computer that controls the transmission under the right side of your dash. Your cross member is slightly different, but can be used. You also need to swap out the clutch pedal and skinny brake pedal for the wider, automatic pedal. The brackets on the throttle body for kick down and all that are all there, they just need to be connected. Also, there is an automatic vs manual TPS. I know there is more to do too, and there are countless threads on it, but these are just some examples. If youre planning on doing this, getting a donor is definitely a step in the right direction. When I went auto to manual, I just put the wrecked, donor XJ in the driveway next to the MJ Link to comment Share on other sites More sharing options...
JeepFanactic Posted January 6, 2016 Author Share Posted January 6, 2016 I see lots of AX15s on craigslist. They are usually listed from $300 to $500. Not sure where in VA you are. I live in Northern Virginia Link to comment Share on other sites More sharing options...
JeepFanactic Posted January 6, 2016 Author Share Posted January 6, 2016 87MJTIM is correct, I see them all day long in the 300-600 range here on the west coast. Have you tried looking on eBay or other online auto part places like carpartwholesale? But to answer your question, you can swap from automatic to manual pretty easily. You will need an automatic computer, because coming out of it there is another harness that goes to a computer that controls the transmission under the right side of your dash. Your cross member is slightly different, but can be used. You also need to swap out the clutch pedal and skinny brake pedal for the wider, automatic pedal. The brackets on the throttle body for kick down and all that are all there, they just need to be connected. Also, there is an automatic vs manual TPS. I know there is more to do too, and there are countless threads on it, but these are just some examples. If youre planning on doing this, getting a donor is definitely a step in the right direction. When I went auto to manual, I just put the wrecked, donor XJ in the driveway next to the MJ Does it matter the donor year? My MJ is a 1987 do I need a Renix engine or does it matter. Thanks for the reply. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 6, 2016 Share Posted January 6, 2016 Any year XJ that came with an AX15 will make a good donor FOR THE AX15. A YJ with an AX15 has a different clocking for the tcase. Link to comment Share on other sites More sharing options...
JeepFanactic Posted January 6, 2016 Author Share Posted January 6, 2016 If I wanted to swap to the Auto would I need to get a donor with the Renix engine 87-90. Thanks Link to comment Share on other sites More sharing options...
87MJTIM Posted January 6, 2016 Share Posted January 6, 2016 If I wanted to swap to the Auto would I need to get a donor with the Renix engine 87-90. Thanks The 87 to 89 1/2 had the BA10. From 2nd half 89 to 93 the MJ/XJ/YJ came with the AX15 with the internal slave set up. From 94 on, the AX15 came with the external slave. I would recommend the 94+ XJ if you just want the trans. Other parts are HO 4.0s. You can use some of the parts, but not all. Also, the tcase that came with the BA10 has 21 splines. The AX15 uses 23 splines. You will need the matching tcase with the AX15. Or, you could rebuild the 21 spline tcase to change the input shaft. For a Youtube video, check out Bleepinjeep for this change Link to comment Share on other sites More sharing options...
relyt120 Posted January 9, 2016 Share Posted January 9, 2016 If I wanted to swap to the Auto would I need to get a donor with the Renix engine 87-90. Thanks My understanding is that yes Renix to Renix would be easiest for this conversion. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 12, 2016 Share Posted January 12, 2016 Contact Paradise XJ here and see what he has to say. Link to comment Share on other sites More sharing options...
