I have been doing a lot of research on the AMC axle in the MJ and it's variants. The thing is I can't find if I should call it an M-20 or M-23. Could an axle guru give a guy a hand! Maybe provide some documentation on how to spot the difference in the two.
The AMC M23 is the FSJ version of the M20 used in AMC cars, CJ's, etc. It is stronger and does not have the 2-peice shafts like the M20. They have flanged shafts and are 6 lug.
What else used the "guts" of the corporate 20?
What do I win if I tell you?
(Yes, I do know. There are a lot of them around and they have diesel engines.)
Hummmmm, interesting..........
Yep. And those rigs had a special version of the differential made by a company I used to work for.
They also have a special version of the transfer case.
