kdexter89 Posted December 23, 2015 Posted December 23, 2015 I have been doing a lot of research on the AMC axle in the MJ and it's variants. The thing is I can't find if I should call it an M-20 or M-23. Could an axle guru give a guy a hand! Maybe provide some documentation on how to spot the difference in the two.
88whitemanche Posted December 23, 2015 Posted December 23, 2015 It is called the amc 20... It was also used in cjs, full size Cherokees, and j-series trucks Here's a thread that gives a good amount of info... http://comancheclub.com/topic/45147-amc-20/?fromsearch=1
HOrnbrod Posted December 23, 2015 Posted December 23, 2015 The AMC M23 is the FSJ version of the M20 used in AMC cars, CJ's, etc. It is stronger and does not have the 2-peice shafts like the M20. They have flanged shafts and are 6 lug.
cruiser54 Posted December 24, 2015 Posted December 24, 2015 What else used the "guts" of the corporate 20?
Eagle Posted December 24, 2015 Posted December 24, 2015 What else used the "guts" of the corporate 20? What do I win if I tell you? (Yes, I do know. There are a lot of them around and they have diesel engines.)
HOrnbrod Posted December 24, 2015 Posted December 24, 2015 I thought everyone knew that...............
cruiser54 Posted December 24, 2015 Posted December 24, 2015 Hummmmm, interesting.......... Yep. And those rigs had a special version of the differential made by a company I used to work for.
cruiser54 Posted December 24, 2015 Posted December 24, 2015 I work on those trucks every day Teehee,,,,,,,,,
Eagle Posted December 25, 2015 Posted December 25, 2015 Hummmmm, interesting..........Yep. And those rigs had a special version of the differential made by a company I used to work for. They also have a special version of the transfer case.
