Waterless Coolant
snakedoc67
I have it in a spots car. Hi temps etc. I haven't run the car in a long time though. I put it in in the late 80's early 90's. Temps run higher. Suppose to be drawing out more heat. No sure I'd use it in my XJ's or MJ. OEMs probably don't use it for cost. Also, can't add water in an emergency. There are other fixes to cooling temps in the MJ/XJ.
