89eliminator Posted June 15, 2007 Share Posted June 15, 2007 i have a 6in lift on the front of the MJ. Whenever i take turns, it makes a clunking sound. i just replaced the axle side upper control arm bushings but it still makes the sound. any suggestions. Link to comment Share on other sites More sharing options...
ROADLESS Posted June 15, 2007 Share Posted June 15, 2007 Have you checked your trackbar? There should be no 'play' in it :wrench: Link to comment Share on other sites More sharing options...
jp4lo Posted June 15, 2007 Share Posted June 15, 2007 I bet you can see where the track bar bolt at the axle end has been shifting around under stress. It can be a tough one to keep tight. I've had luck w/ grade 8's and red loctite. Link to comment Share on other sites More sharing options...
mfpdm Posted June 15, 2007 Share Posted June 15, 2007 Is it a single clunk or a series of clunks? Also at what point does it start and stop? Have you check your spring buckets? I had the spring bucket come loose on another vehicle and it would clunk when turning. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 15, 2007 Share Posted June 15, 2007 I would check trac bar too. Also, do you still run the sway bar? The sway bar clunks into the coilsprings if you don't move the sway bar mounts up a inch. Link to comment Share on other sites More sharing options...
mfpdm Posted June 15, 2007 Share Posted June 15, 2007 Have you check your spring buckets? I had the spring bucket come loose on another vehicle and it would clunk when turning. I'll do it before soemone else does; :thwak: MJ doesn't have the same set up. :fool: Link to comment Share on other sites More sharing options...
89eliminator Posted June 15, 2007 Author Share Posted June 15, 2007 the track bar is tight and doesn't have any play. could it be the shocks? Link to comment Share on other sites More sharing options...
87manche Posted June 15, 2007 Share Posted June 15, 2007 I don't see why the shocks would clunk only when turning. They should clunk anytime you hit anything rough as well. A few more questions: Can you feel the clunk through thw wheel? Can you feel the clunk under the floorboards? Do you have swaybar disconnects? Have you checked all of the TRE's for play? Does the steering wheel have a dead spot? Link to comment Share on other sites More sharing options...
Eagle Posted June 15, 2007 Share Posted June 15, 2007 Whose lower control arms do you have in? At stock height I had a clunk in the '87 MJ, and replacing the driver's side LCA cured it. Rusty's adjustable control arms are notorious for clunking. Link to comment Share on other sites More sharing options...
89eliminator Posted June 15, 2007 Author Share Posted June 15, 2007 i can feel the clunk through the floors. yes i do have rustys adjustable arms. Link to comment Share on other sites More sharing options...
Eagle Posted June 16, 2007 Share Posted June 16, 2007 yes i do have rustys adjustable arms. Now how did he know that? I don't think there's a cure. Wear thick socks and turn up the stereo. Link to comment Share on other sites More sharing options...
89eliminator Posted June 16, 2007 Author Share Posted June 16, 2007 anyone got some non-rustys adjustable control arms for sale ;) i don't get it. i love the springs i have already. they ride and flex nice. Link to comment Share on other sites More sharing options...
bhorocks Posted June 16, 2007 Share Posted June 16, 2007 always worth checking the shock bushings anyways. can't hurt Link to comment Share on other sites More sharing options...
