Valve Cover Gasket ?
Short answer is no.
I'm using the newer style blue felpro on my '98 engine with an '89 aluminum cover. I only recently realized that there was a difference in gaskets and that they should match the cover you are using. I have a small leak at the back of the engine that tells me it's not sealing properly. I plan to swap out shortly.
I have an 88 with a blue rubber gasket (I'm assuming for an 88) I've had that cover off at least 4 times and it still doesn't leak at all.  So ask the parts store for a gasket for a 92.  Unless there's a different reason for wanting the 97+ style.
No, not in the quarter. but I did make a few runs at the local 1/8 mile track when I first got the stroker in 05. Best time was 9.80 @75mph. 4.6L, AW4, 2WD, with street tires and a camper shell. AW4's and D35's suck for drag racing. Snapped two axles before installing the D44.   :rotfl2:
Have done a lot more mods since then, but the track is gone now............
I have a 93 engine with a 97 stamped cover. I use the new gasket with that cover.
On a unrelated note. My engine has had a lifter tap since I put it in a few months ago. I just wrote it off as a old worn out engine. When I pulled the cover to replace my gasket I noticed the front two rockers were hitting the cover. I hit the cover a couple times with a hammer  where they were making contact. It got a little better but needs more clearance to remove the tap completely. I got lazy and said screw it, they will self clearance. I'm not sure why the rockers are hitting the cover but they are?
About a month or so after I bought my Renix XJ in 2008, I went to Sac raceway for "Mopar Magic" and met up with a few of the dakota guys that I used to hang with. At the time, my XJ was basically stock; 4.0L/AW4/Np231/D35,D30, and newish 235/75R15 Bridgestone Dueler A/T 693's. My time progressively got better as I ran. Best time was 1/4 mile time was 17.4s @ 76MPH in 4WD!
Not as good as your run. But I would say pretty damn good for a box on wheels.
Wish I could have run my MJ with the 4.56's and the 235/75's, but hopefully someday to set a benchmark to progress.
One thing that makes me laugh in my head is when I went to purchase for the race, was when the guy says "This is a Jeep, not a mopar." To this I remarked "Technically 'No', however AMC was bought out by Chrysler therefore it actually IS associated." The guy thought about it and then said "Okay"
Back on topic, I have the felpro rubber gasket on my renix MJ and it doesn't leak a drop.
I have the cork POS on my XJ and I think it's leaking again.. For some reason the last time I checked the VC bolts were a little loose as well. This was the case as well when I first bought my XJ. Had an oil leak, checked/tighten the VC bolts and the leak stopped. Now, my rear main leaks.. FML. I just make sure it's filled correctly with oil and am waiting to do an lS-based motor swap at some point.
