Alexia Posted July 18, 2015 Share Posted July 18, 2015 Because of these dumb BFG MT tires I have I basically have to be super light on the throttle to keep from spinning. Detroit Truetracs are on sale right now with an additional rebate. My research says they are the best to use outside of a factory limited slip. Does anyone have experience with them in their trucks? Link to comment Share on other sites More sharing options...
Eagle Posted July 18, 2015 Share Posted July 18, 2015 I have a Truetrac in the red '88 shortbed. I love it. It provides a much more positive lock than the factory Trac-Lok. I drove Old Red through two New England winters and almost never had to use 4WD -- even without putting weight in the bed. Link to comment Share on other sites More sharing options...
91Pioneer Posted July 18, 2015 Share Posted July 18, 2015 I put one in my 2WD Ranger. It was expensive but helped me get around (with sandbags in the bed), I'd say they work. Link to comment Share on other sites More sharing options...
Alexia Posted July 18, 2015 Author Share Posted July 18, 2015 Thanks! I will pick one up and have it installed soon. Link to comment Share on other sites More sharing options...
Megadan Posted July 18, 2015 Share Posted July 18, 2015 Truetrac, and other helical type diffs, have an advantage of being very smooth and very positive engagement. Their own real downside is that if you do any sort of off-roading where one of the wheels leaves the ground, it will spin like an open diff. A nifty little trick to make them lock up again is to lightly apply the brakes though. As long as both wheels see even a little bit of resistance it will act like a limited slip. I want truetrac diffs front and rear on my truck someday... Link to comment Share on other sites More sharing options...
Incommando Posted July 18, 2015 Share Posted July 18, 2015 Far better than a factory LSD. Sort of in between a Standard LSD and a locker if you know how to use them. If you drag your brakes ever so slightly when things are bad they actually lock to some degree. I only have experience with them in a front application, though. They are invisible in the front so should be in the rear as well Link to comment Share on other sites More sharing options...
Eagle Posted July 18, 2015 Share Posted July 18, 2015 They also don't have clutches, so you don't have to worry about friction modifier. Link to comment Share on other sites More sharing options...
CobraMarty Posted July 19, 2015 Share Posted July 19, 2015 I have them in 2 of my XJs and F150. Love em, wouldn't use anything else for the type of use we do. Link to comment Share on other sites More sharing options...
