Kenosha Warrior Posted June 7, 2007 Share Posted June 7, 2007 I need measurements for the 2wd and 4wd MJ rear driveshafts for a SWB. Link to comment Share on other sites More sharing options...
Pete M Posted June 7, 2007 Share Posted June 7, 2007 You need to specify auto or manual, Dana44 or Dana35. :D Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted June 7, 2007 Author Share Posted June 7, 2007 D35 rear. I need measurements for: AX4 2wd AX5/AX-15 4wd AW4 4wd I have eyes on a 4wd AW4 rear DS for a 231/d35 combo. I would be using it on a AX5/231/D35 setup. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted June 8, 2007 Author Share Posted June 8, 2007 Anyone? Link to comment Share on other sites More sharing options...
Tracker Posted June 8, 2007 Share Posted June 8, 2007 I just happen to have one laying in my garage. From u-joint center to u-joint center it is 58.5 inches. This is from an '89 2wd, 2.5L, AX4, D35. I saved it because it is one of those that is encased in a rubber lined tube. It may get cut down to work on the lifted 4wd. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 8, 2007 Share Posted June 8, 2007 he already has the same one, he needs to know the length of the cut or what would work as a substitute Link to comment Share on other sites More sharing options...
BARILLMS Posted June 9, 2007 Share Posted June 9, 2007 Its long. Link to comment Share on other sites More sharing options...
Pete M Posted June 10, 2007 Share Posted June 10, 2007 I finally remembered to go measure my 4.0L/AX-15/4wd/dana35 and I got 43.5" Link to comment Share on other sites More sharing options...
mfpdm Posted August 2, 2007 Share Posted August 2, 2007 D35 rear. I need measurements for: AX4 2wd AX5/AX-15 4wd AW4 4wd I have eyes on a 4wd AW4 rear DS for a 231/d35 combo. I would be using it on a AX5/231/D35 setup. Dug this up because I'm in need of the same info and it looks like this did not get fully answered. I'm looking at getting a rear DS from a 4wd BA10 SWB and I need to know the lenght of the rear DS for a 4.0 4wd AW4 D35 and/or D44. Maybe if we could get all the DS combo's answered we could make this a sticky. :cheers: Link to comment Share on other sites More sharing options...
beaterjeep Posted August 2, 2007 Share Posted August 2, 2007 If I knew exactly which tcase I have, I could get a measurement in the morning. Link to comment Share on other sites More sharing options...
rockhardzj Posted August 2, 2007 Share Posted August 2, 2007 my old 4.0/ba10/2wd d-shaft for a SWB is 53" on the nose. It's a Deluxe D-shaft. Link to comment Share on other sites More sharing options...
rockhardzj Posted August 2, 2007 Share Posted August 2, 2007 If I knew exactly which tcase I have, I could get a measurement in the morning.look at the tag on the back, in the middle area. the top will say 242, or 231J Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 2, 2007 Share Posted August 2, 2007 beaterjeep, you have an np207 or an np242 242 I believe because you have selec-trac Link to comment Share on other sites More sharing options...
beaterjeep Posted August 2, 2007 Share Posted August 2, 2007 beaterjeep, you have an np207 or an np242 242 I believe because you have selec-trac That I do, and have the 35 rear with the 3sp auto. I can still get a look and measurement in the morning if anyone would like. Link to comment Share on other sites More sharing options...
MrShoeBoy Posted August 2, 2007 Share Posted August 2, 2007 I got a driveshaft out of a 6 cylinder manual, NP231, and Dana 35. The t-case has a JB conversions heavy duty SYE on it. I can check the length on the shaft tomorrow. Any takers? AARON Link to comment Share on other sites More sharing options...
mfpdm Posted August 2, 2007 Share Posted August 2, 2007 Any and all measurements are welcome. Would like to get all the different lengths with all the different engine/tranny/tcase/axle combinations. So far this is what has been posted: 4.0/ba10/2wd/D35 d-shaft for a SWB is 53" 2wd, 2.5L, AX4, D35 is 58.5" SWB 4.0L/AX-15/4wd/dana35 is 43.5" (Is this short / long bed and need to know tcase) I'm pretty sure that with all the members on here, we could have all the factory combo's represented. :cheers: Link to comment Share on other sites More sharing options...
rockhardzj Posted August 2, 2007 Share Posted August 2, 2007 I said 2wd, as in NO tcase. the front axle is nothing more than a tube, no drive components. I should actually add in, thats a D35 rear. I actually think we should get the proper lengths posted for after lifts, and at what height, gets a ballpark figure much easier. Link to comment Share on other sites More sharing options...
beaterjeep Posted August 2, 2007 Share Posted August 2, 2007 SONUVA..... I knew I forgot to do something today. And I was even out finishing up on the 86 today too. I still have to go back to it and grab a few things on tuesday noonish, so if someone could please remind me then to take the measurements and look to see which tranny and tcase I have, it would be greatly appreciated. Link to comment Share on other sites More sharing options...
mfpdm Posted August 3, 2007 Share Posted August 3, 2007 I said 2wd, as in NO tcase. the front axle is nothing more than a tube, no drive components. I should actually add in, thats a D35 rear. I actually think we should get the proper lengths posted for after lifts, and at what height, gets a ballpark figure much easier. Ooops :thwak: I fixed it. got carried away with the cut and paste. :brows: Link to comment Share on other sites More sharing options...
rockhardzj Posted August 3, 2007 Share Posted August 3, 2007 I said 2wd, as in NO tcase. the front axle is nothing more than a tube, no drive components. I should actually add in, thats a D35 rear. I actually think we should get the proper lengths posted for after lifts, and at what height, gets a ballpark figure much easier. Ooops :thwak: I fixed it. got carried away with the cut and paste. :brows: I want to :thwak: some people in this world :D Your not on the list though. Link to comment Share on other sites More sharing options...
Tracker Posted August 3, 2007 Share Posted August 3, 2007 2wd, 2.5L, AX4, D35 is 58.5" (Is this short / long bed) It's short bed Link to comment Share on other sites More sharing options...
nipcat202 Posted September 9, 2007 Share Posted September 9, 2007 I got a driveshaft out of a 6 cylinder manual, NP231, and Dana 35. The t-case has a JB conversions heavy duty SYE on it. I can check the length on the shaft tomorrow. Any takers? AARON Let me know the length, center to center on the u-joints. email me at (gintar@netrover.com) Roy Link to comment Share on other sites More sharing options...
