big66440 Posted June 26, 2015 Posted June 26, 2015 I was wondering if the H802CP pistons could be used in an 89 4.0 with a 7120 cylinder head? the only difference I was able to see was the H802CP pistons had about a .007" taller compression distance than the correct ones listed for the 1989 4.0 engines ( part number 677AP). Reason I ask is because the H802CP pistons have a coated skirt, they're cheaper and according to the federal mogul website they are 165 grams lighter per piston/pin combo compared to the 677AP.
Jeep Driver Posted June 26, 2015 Posted June 26, 2015 Without looking it up, I doubt the .007 is even the thickness of the head gasket. I forget what Sealed Power pistons I used.........they are just about all coated anymore. I assume you are going with a full set? for weight difference? They should be fine.
johnj92131 Posted June 27, 2015 Posted June 27, 2015 802 piston is hypereutetic while the 677 piston is a cast piston
cruiser54 Posted June 27, 2015 Posted June 27, 2015 Head gasket is at least .052" thick. I'd use them.
