Rear Disc Conv. E-brake...
I've got most of my parts together for my rear disc swap and WJ Booster and Master upgrade.  I do have new E-brake cables already for the truck, but I do know that the cable ends for the E-brake are different, and that the ZJ e-brake cables are roughly half the length of the MJ which makes them not really useable.  I've done a little searching on the swap, but all of the XJ info out there simply says "use ZJ cables" and I don't find much of anything useful that is MJ Specific.
What I am looking for is links, pics, etc of what you or someone else has done to solve the E-brake actuation with the ZJ rear discs.  As it stands I can still do the swap and be no worse for wear because my e-brake doesn't work with my drums either (front cable broke), but it would be nice to have an actual working e-brake some day.
  On 6/24/2015 at 1:04 AM, Jeep Driver said:
Get two passenger cables........DS is a stretch.
All of the off the shelf cable measures of a ZJ passenger side are 43" (rounded up) while the rear Comanche cables are 52" (rounded up).  That's a 9" difference in total length, which is quite a bit.  Did you move the loop hangers for the cables, or maybe run them differently?
Use the cables from a Liberty or an Explorer, passenger side. The Grand Cherokee cables were too short even for my Cherokee, used an Explorer passenger side and I have so much extra length I had to loop it. Should work fine for an MJ (I plan to use the same when I finally convert my Comanche this summer).
That's not a bad idea.  The Liberty and explorer cables are 77-78" in length, which is defintely longer, but there may be a way to work around it better.  At least I would have slack if I do a lift later.  :laughin:
Doing a search, the 2006 Grand Cherokee and Commander rear parking brake cables seem to be a potential winner.  They are only about 1-2 inches shorter than the MJ Cables and look to have the correct ends on them.  I may order one and see
Well, cost depends on how you want to go.  I went to the junkyard and removed the backing plate/bracket/dust shield from a ZJ for $15 each and cleaned them up and I'm going to paint them black.  I bought rebuilt calipers for $18+5 core(ea.) and rear pads for $15 from a buddy that works at a parts store.  Parking brake hardware and  shoes and rear rotors off rock auto for about $60 shipped.   So maybe $150 ish,  new cables will be another $30ish and any other small misc costs for hardware on top of that.  Just round it off and call it $200, but that was for 90% new/rebuilt stuff.  You could probably get it done cheaper with used bits, but I prefer to start fresh.
