fiatslug87 Posted June 28, 2015 Share Posted June 28, 2015 I know you're past this, but in case someone is searching, instead of using a puller or packing grease/bread use wet toilet paper. Wet it, stuff it in, pack with a large punch/bolt/steel rod, repeat. This method was posted by HKB3 and really works GREAT, with minimal mess. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted June 28, 2015 Author Share Posted June 28, 2015 Researched and figured it all out. Loctite was applied. Tranny is back in! Gonna reconnect everything else slowly as I come in from work in the mornings. Hoping everything goes as planned! Link to comment Share on other sites More sharing options...
Megadan Posted June 30, 2015 Share Posted June 30, 2015 On 6/28/2015 at 9:47 PM, Knucklehead97 said: Researched and figured it all out. Loctite was applied. Tranny is back in! Gonna reconnect everything else slowly as I come in from work in the mornings. Hoping everything goes as planned! Good stuff! I saw that you had the same issue I did with the 2 piece pilot bearing coming out. I managed to get mine with a slide hammer puller, but it was a long and frustrating experience. Soon you will be driving again, and you can spend the first couple hundred miles sweating about if you did it right. After that, and the clutch is broke in, you can enjoy your hard work lol. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 1, 2015 Author Share Posted July 1, 2015 I've been sweating so bad about if its put in correctly lol, still gotta install the rest of the stuff (t-case, driveshafts, fluid, ect) but it should be back together next week. Then just to test the clutch out and have a buddy come pick it up to take to a shop with a renix scanner to get it running smooth! Then fuse block change. And all sorts of goodness to come :D Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 10, 2015 Author Share Posted July 10, 2015 The clutch works! Gosh it starts off so smoothly now!!! I'm thrilled! Saved a bunch of money and gained so much knowledge changing it myself. Thanks for all the help, guys! Oh, and check out the bullbar I got a couple months ago. Been wanting one of them since I got the truck :D now just to do the fuse block and get it in a shop and I think I'll be good on drivability problems for now and can move on to upgrades! Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2015 Share Posted July 10, 2015 :banana: Link to comment Share on other sites More sharing options...
Megadan Posted July 11, 2015 Share Posted July 11, 2015 Woohoo! Good job! Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 Now here's a quick question, of course. I gravity bled about 3/4's of a quart of fluid through the clutch system just to make sure its done well. And my pedal is softer than it was? It isn't spongey or anything. Just easier to push in. And after the first half it gets easier to push in. Is all of this normal? Also my clutch releases wayyyy lower, It's pretty awesome so far :D Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 And thanks, guys! :D Link to comment Share on other sites More sharing options...
Megadan Posted July 11, 2015 Share Posted July 11, 2015 Softer feel but not spongy is most likely just the pressure plate design. As long as the clutch fully engages/disengages, then I wouldn't worry. The low clutch engagement is a good thing too, that means there's lots of clutch (it's new). It's when the release point is really high that tends to be a good sign of a worn clutch that will need replacing soon.P.S. Take care not to floor it, or rev to high, for a couple hundred miles. Avoid interstate driving as well, and avoid sustaining the same RPM for extended periods. You want to make sure that clutch breaks in properly. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 Mine only had an 1/8" of pedal once it started grabbing. Horribly high. Thats the entire reason I changed it. And as far as I can tell it's fully engaging and disengaging. It doesn't seem to have trouble sitting still in gear with the clutch disengaged. And engaging seems correct. I just have to get used to an all new pedal feel now! Link to comment Share on other sites More sharing options...
Megadan Posted July 11, 2015 Share Posted July 11, 2015 Yeah, I had to re-learn to clutch when I did my AX-15 swap. The clutch in front of the BA10 in my truck was the factory original unit and was a bit worn. It took me a few days to be smooth again (good ol' herky jerky starts) Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 Oh yeah, plenty of herky jerky. And the occasional spinning of tire in my mothers front yard... whoops. Link to comment Share on other sites More sharing options...
desertmike Posted July 11, 2015 Share Posted July 11, 2015 I put a Centerforce in the Comanche and it takes alot more leg pressure than the wifes XJ with an Amazon Prime unit in it Don't remember whose. Both have AX15's and external slave, etc. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 I think the one that was in the Comanche before I changed it was a Luk heavy duty. It was a Luk, but I think the numbers were different. Link to comment Share on other sites More sharing options...
