Once again, couldn't decide if this would be better in the Pub, or MJ Tech.  As it's not an MJ, but an XJ, I've posted here.
I've found another XJ that has my interest.  It's a 4 owner vehicle with a detailed history.  I've pasted a segment of the CarFax report below and need some expert feedback on what it's really saying.  The following history is from June 2013 through March 2015.  Only about 8K miles put on it in that time, but it appears as though everything was replaced.  Of particular interest, what do they mean when they write "Long block replaced"?
06/10/2013     Washington Motor Vehicle Dept. Seattle, WA
Registration issued or renewed
Exempt from odometer reporting
Vehicle color noted as Green
07/31/2013   202,012   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com
Oil and filter changed
Engine/powertrain computer/module checked
Driveshaft universal joint(s) replaced
Spark plug wires replaced
Distributor cap/rotor replaced
Axle(s) replaced
10/02/2013   202,285   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com   Transmission fluid flushed
Water pump replaced
Valve cover gasket(s) replaced
Radiator repaired
Flywheel/flexplate replaced
Long block replaced
Starter replaced
Battery/charging system checked
12/17/2013   202,807   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com
Tires rotated
01/28/2014   203,179   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com
License plate light bulb(s) replaced
Idle control valve/motor replaced
04/16/2014   203,740   Budd & Company, Inc.Seattle, WA 206-324-0550 buddandcompany.com   Maintenance inspection completed
Brake caliper(s) replaced
Front brake pads replaced
Brakes checked
Front brake caliper(s) replaced
06/13/2014     Washington Motor Vehicle Dept. Seattle, WA
09/04/2014   205,906   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com
11/25/2014   207,036   Budd & Company, Inc. Seattle, WA 206-324-0550 buddandcompany.com
Intake manifold gasket(s) replaced
Exhaust system checked
Engine idle checked
PCV hose replaced
03/15/2015   209,472   Dealer Inventory   Vehicle offered for sale
I believe it means, the block or top and bottom end were replaced, but much of the internal like oil pump, water pump other, were from the previous engine.
don't quote me though, i've been proven wrong more then once about jeep things :P
A short block is just the block and all internal parts. No head. A Long block includes the head. and may or may not include the valve cover(s).
So, with that snap shot of the Carfax, what would your opinion be on longevity of the motor/drivetrain?
It either has a new/remanufactured motor or one from a junkyard(probably a new/reman). In either case if it drives ok and sounds ok it wouldn't be anything I would be worried about. What year is it?
Overall it looks pretty good (in pictures).  It's a '98 2 door.  Has nearly everything I want.  Only problem is the distance. 2543 miles away.
Pictures can tell you a lot, but there's no telling when it comes to mechanical issues.
Anyone in Seattle willing to take a look at it for me?
