schardein Posted March 19, 2015 Share Posted March 19, 2015 1991 Jeep Comanche Sport Truck 4.0/Auto/2wd/D35/shortbed Build date 10/90 Bought in Maryland, currently in Missouri. Mileage at purchase was 143,xxx. This is my first Comanche. Been looking for a 1991 or 92 for a long time. Truck is white with SporTruck graphics, and burgundy interior. Was very original when I got it. I found the factory build sheet stuffed in the seat springs under the seat on the pass side. It was a radio delete model. It had a Jensen shaft style radio that I suspect was dealer installed. Very clean installation. They cut the door panels to install the speakers, but did it very clean and used the factory mounting points. The just poked holes in the plastic door grommets to run the speaker wires. Column shifter, no gauges. Manual locks and windows. Bench seat. Black vinyl floor. It does have AC. It has the factory jack, handle, and mounting bracket. No owners manual though. I've since added a lot of "factory" upgrades. -Exhaust manifold (original was cracked, like they all are!) -Late model intake manifold -Late model valve cover with blue gasket -Cruise control -Rear carpet piece on back cab wall -Door panels with proper speaker grills, door pockets, and large door handles -Woodgrain dash panel -Factory fog light switch and wiring -Deleted the power/comfort switch -Added an auto dimming inside rear view mirror with compass and temp -Rear speaker brackets and speakers -Late model door mirrors -Factory front skidplate -Factory clock -Factory headlight delay -Factory under dash courtesy lights -Factory windshield washer level sensor -Late model electric engine cooling fan I bought this planning a 97+ front end conversion and 4wd conversion. The 97+ front end is cancelled, but still plan to do a 4wd conversion eventually (I have two CJ projects in front of this). I've got a factory Dana 44 standing by as a starting point. These were taken right after I got it home Interior. I added the burgundy horn button to see how I liked it. I didn't. Went back to the original black one. Image Not Found Late model mirrors Link to comment Share on other sites More sharing options...
Minuit Posted March 20, 2015 Share Posted March 20, 2015 That woodgrain dash bezel looks really nice against the maroon dash :thumbsup: Link to comment Share on other sites More sharing options...
schardein Posted March 22, 2015 Author Share Posted March 22, 2015 Thanks! Realized I haven't haven't taken many pics since I first got it. Gonna get it cleaned up and take some. Link to comment Share on other sites More sharing options...
schardein Posted March 22, 2015 Author Share Posted March 22, 2015 As it sits March 2015 Link to comment Share on other sites More sharing options...
jayzauto Posted July 30, 2015 Share Posted July 30, 2015 Hey that my truck lol and it's in mo. Lol I got a 91 base sport truck 4x4 inline auto. Mine is hunter green with same grafics Dana 30 Dana 35 and 217 on body 38k on motor out of 99 grand Cherokee but I still have factory motor I'll upload pics later tonight Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *B1 TRIM STYLE B1 - CLOTH && VINYL BENCH SEAT -H9 135 Zone 35-Washington 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount ALA SE Decor Group ALK Italia Package APA Monotone Paint BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body Model TL61 Build Date 10/29/90 Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: LOWE JEEP EAGLE Upper Marlboro, MD Link to comment Share on other sites More sharing options...
schardein Posted February 1, 2021 Author Share Posted February 1, 2021 15 hours ago, jdog said: Selling Dealer: LOWE JEEP EAGLE Upper Marlboro, MD Very cool, thanks for looking this up for everyone. This means my tailgate dealer plaque is original! Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 You are welcome Link to comment Share on other sites More sharing options...
