Please Help Identify this Connector
Hello,
As stated in the subject please help identify this connector. There are three wires Blue/black, Yellow/black and Tan.  The blue/black wire is not connected (looks as  if it was cut) and i cannot find the wire it should connect, nor can I find the mate for the harness connector.  I have searched the schematics with no luck.
Thank you
Guys my apologies for not being more descriptive. My truck is an 87 I6 4wd 5 speed. The harness is located under dash and is near the accelerator and ECU. I did find a black ground wire that isn't attached to a connector, however did not think it would attach to the blue/black wire in the above photo.
