The fuel in the rail is under pressure, yes. Is it being compressed? Not really, but that's just semantics.
If your injector o-rings are leaking enough to cause running problems, there would be a noticeable fuel leak.
X2 on Cruiser's Renix Tips.
The injectors are in the intake, not the head. If you're compressing air into the intake, you've got bigger problems than leaking injectors. Bad intake valves/seals, as suggested... Or else you're turning the engine backwards...
As others have mentioned, this is a common issue with the ballast resistor failing. It is on the driver side inner fender in front of the egr vacuum solenoid. Disco the wires and jumper them together. If necessary, a paper clip will work for this. Then try to start/run it. If it runs, you found your problem. You can permanently bypass this without issue. Or you can buy a new one and hope it doesn't fail.
