thejim42 Posted February 1, 2015 Posted February 1, 2015 How many miles can I expect to get out of a ba10? I need a new trans for my truck and I can get a ba10 for a lot less than an ax15 and money is kinda tight right now. If I'm just doing normal everyday driving what would the life expectancy be?
mnkyboy Posted February 1, 2015 Posted February 1, 2015 I've seen them with over 200,000 miles and still going.
91Pioneer Posted February 1, 2015 Posted February 1, 2015 Drive it nice and you're good. Put in new fluid, the right stuff though.
thejim42 Posted February 1, 2015 Author Posted February 1, 2015 What is "the right stuff"? I made the mistake of putting gl4 or gl5. Don't remember which and it tore up my syncros and bearings. Which is why I need a new trans
87MJTIM Posted February 1, 2015 Posted February 1, 2015 275k on mine and still going. I was told by a manual trans mechanic to use Pennzoil Synchromesh.
nitroxsteve Posted February 1, 2015 Posted February 1, 2015 My ba 10/5 is the only original piece of my trucks drive train. Engine was rebuilt and the rear end has been replaced.
Eagle Posted February 1, 2015 Posted February 1, 2015 What is "the right stuff"? I made the mistake of putting gl4 or gl5. Don't remember which and it tore up my syncros and bearings. Which is why I need a new trans 287,000+ for the one in my '88 Cherokee. GL5 is the recommended gear lube for the BA10/5. That's all mine has ever seen. It's the AX-5 and AX-15 that should not see GL4 or GL5.
