TheDude Posted January 7, 2015 Share Posted January 7, 2015 Hello again, with it finally snowing here for real and my not being able to get up the hill to my house without 4WD, I figure it's finally time to get around to putting my front driveshaft back in. The only my problem is, I lost the bolts for the transfer case side.. Does anyone know what size they are, or have a spare set laying around? Thanks. Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 7, 2015 Share Posted January 7, 2015 I forget the size but I used regular allen head cap screws. 5/16 24 x 1 1/4 ...something like that. Link to comment Share on other sites More sharing options...
banshee Posted January 7, 2015 Share Posted January 7, 2015 Please use atleast grade 5 or harder bolts OK? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 7, 2015 Share Posted January 7, 2015 Daveys , he might ship them to you . Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 7, 2015 Share Posted January 7, 2015 J0181613, 4, FRONT PROPELLER SHAFT BOLT, SIZE 5/16x24x1.1706034966, 4, (Alternate part for J0181613 if the hex head is too big use this one.) Link to comment Share on other sites More sharing options...
Blue XJ Posted January 7, 2015 Share Posted January 7, 2015 Why waste the time? Ace (or any decent hardware store) should have them on the shelf. Link to comment Share on other sites More sharing options...
Rockfrog Posted January 8, 2015 Share Posted January 8, 2015 A regular off the shelf Allen head capscrew will be stronger than a typical gr5 bolt... Unless you got them from Chang's Import Hardware ... nothing against Chang though. Link to comment Share on other sites More sharing options...
TheDude Posted January 8, 2015 Author Share Posted January 8, 2015 Thanks for all the replies. It seems I'll have to get these at the hardware store since the only place I could find them online wanted $30 for them.. Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 8, 2015 Share Posted January 8, 2015 Cut off 1" of an allen wrench, 1/4". That was the reason I swapped mine out. Nothing like spending more time taking out 4 bolts of the DS than removing the entire transmission. My front DS bolts are now at my rear DS. Image Not Found Link to comment Share on other sites More sharing options...
