Jacob Ochs Posted November 21, 2014 Share Posted November 21, 2014 Earlier this year I had my MJ realigned after putting my lift on just to figure out that the previous owner had most likely jumped it and bent the tubes upwards on each side 2.7-3.7*. He must of been a really smart guy. But anyways I had thought of an idea! I have 2 anchors in my garage floor. I was thinking of anchoring the axle on each side and putting a floor jack underneath and slowly jacking it up till it was at the correct angle; all the while heating it up. After that I was going to Fab a over axle truss for it and weld the axle tubes in the diff. I've resorted to this because for the last year I've been looking for a Dana 30 with 4.11 gears (that's what I have now) and can't find one; or they're at an outrageous price 400$+. Also it is slowly wearing the inside of my tires out but most importantly it looks like I tried to ricer stance it with negative camber. :rofl: No one likes ricers. So my question is has anyone done this before? Also do you think this is a good idea? I will make a thread for it if this is what I decide to do. Any input is appreciated! :) Link to comment Share on other sites More sharing options...
nitroxsteve Posted November 21, 2014 Share Posted November 21, 2014 If it were me I would get a complete D30 from the jy for about $100 and put the guts from the old axle inside. This would let me do all of the truss work while keeping the truck on the road. Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 21, 2014 Author Share Posted November 21, 2014 If it were me I would get a complete D30 from the jy for about $100 and put the guts from the old axle inside. This would let me do all of the truss work while keeping the truck on the road. I've thought of this. The only problem being the area I'm in; believe it or not all the junk yards lack Cherokees! And the axle prices are very high if I find them! I also try to avoid ring and pinion work as much as possible. I hear its a pain. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 21, 2014 Share Posted November 21, 2014 I know a guy that has run several axles with the same set of 4.10 gears. He just keeps all the shims and bearings together that were on the set originally and installs it in another axle. This works ok for the front because it's not used all the time like the rear is. Link to comment Share on other sites More sharing options...
joester1908 Posted November 21, 2014 Share Posted November 21, 2014 It might be worth a shot, but id just look to replace the axle. Is there any other damage from jumping it? Link to comment Share on other sites More sharing options...
jimoshel Posted November 21, 2014 Share Posted November 21, 2014 I've done it twice. Once to a '60CJ and again to a '70 J10. I didn't have any loops in the garage floor I trusted so I rolled the front wheels onto a steel girder and used it. Wrapped a heavy chain over the far outer end of the axle and beam and placed a 20 ton jack under the differential. The CJ came out perfect the first try. The J10 had to be done twice to get it right. Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 21, 2014 Author Share Posted November 21, 2014 I've done it twice. Once to a '60CJ and again to a '70 J10. I didn't have any loops in the garage floor I trusted so I rolled the front wheels onto a steel girder and used it. Wrapped a heavy chain over the far outer end of the axle and beam and placed a 20 ton jack under the differential. The CJ came out perfect the first try. The J10 had to be done twice to get it right. Okay that's good so I have a chance of getting it. Could you go a little more in depth? Was the axle on the truck when you did it? Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 21, 2014 Author Share Posted November 21, 2014 It might be worth a shot, but id just look to replace the axle. Is there any other damage from jumping it? Not that I've seen but there could be because the spider gears haven't been at their correct angle! But I don't use 4wd often so it's probably fine. Link to comment Share on other sites More sharing options...
jimoshel Posted November 21, 2014 Share Posted November 21, 2014 Both times was the front axle. And yes the axles were on the truck. Link to comment Share on other sites More sharing options...
nitroxsteve Posted November 21, 2014 Share Posted November 21, 2014 I've done it twice. Once to a '60CJ and again to a '70 J10. I didn't have any loops in the garage floor I trusted so I rolled the front wheels onto a steel girder and used it. Wrapped a heavy chain over the far outer end of the axle and beam and placed a 20 ton jack under the differential. The CJ came out perfect the first try. The J10 had to be done twice to get it right. Okay that's good so I have a chance of getting it. Could you go a little more in depth? Was the axle on the truck when you did it? Hey its already messed up what do you have to loose. Link to comment Share on other sites More sharing options...
husky410ohio Posted November 21, 2014 Share Posted November 21, 2014 Here from 4 wheeler how to straighten it: http://www.fourwheeler.com/how-to/transmission-drivetrain/1410-straightening-a-bent-dana-44-axle/photo-01.html To add on to the long line of “oops” moments we’ve had, we recently realized that a junkyard axle we grabbed, for what seemed like a steal, was bent. The plan was to build this cool full-width Ford F-150 high-pinion Dana 44 for one of our Jeep projects. The high-pinion design makes for great front driveshaft angles, and due to the nature of how a front axle turns relative to the gear, the high-pinion design means this axle is stronger than a low-pinion axle. Also, the tubes have a stout 1⁄2-inch wall thickness, so this axle should be difficult to bend. Or should have been difficult to bend; more on that in a minute. As plans changed and time passed, the axle spent way too much time sitting on jackstands in our garage, doing nothing but taking up space. We collected parts for a rebuild, and as our axle rebuild story’s due date was rapidly approaching, we dusted it off and started once again messing with the axlehousing. We had taken the axle down and had it sand blasted it some time back, and that makes working with it nice. Now, as we started working on the axle and used a plasma cutter to cut off the old axle brackets, we noticed a near-fatal problem with the axle: It was bent. It was hard to see the bend unless you stared at the axle for a while or peered down the axletubes. Poo. What now? Is it junk? Is it now only worth its weight in scrap steel? All our plans and parts collecting were for nothing—or so it seemed. Luckily for us, we had contact with a place that should be able to help us out. That place is Arizona Differential in Phoenix, Arizona. With one call, the owner, Nate, told us to drag our “slightly bent” axle down to him the next day. When we got there, Nate directed us to Tim Adkins who helped us straighten our axle that, as it turns out, had way more problems than we thought. In the end, our junkyard axle has a little bit more money invested in it, but its way stronger and probably straighter than the day it drove out of the Ford factory. Luckily for you, we also grabbed our camera and snapped a few pics to check show how the axle was straightened and strengthened. Instead of being junk headed for the steel recycler, our junkyard axle is now better than ever. Here is the axle. Can you see the bend? It’s subtle, but it’s there. It looks like maybe the Ford truck the axle came from was jumped and the axle bent in a very slight smile. Looking down the inside of the axle is the best way to see even a slight bend. If you line up the center of the two axle openings and the center is not perfectly inline, then your axle is bent. Unfortunately, it’s next to impossible to take a picture of this view, but see how the opposite opening looks egg shaped. Here, Tim shows us one part of the key to straightening an axle. That is a 1.5-inch solid piece of stainless steel that is about 6 feet long (top). Another key to the straightening are two of these pucks (bottom) where the outside diameter fits snuggly under the axles bearing caps. The inside diameter is the same as the stainless steel rod. With the pucks installed in the axle, you can slide the rod through the axle and see how the axle needs to be bent the opposite way to straighten it. Here, Tim shows us one part of the key to straightening an axle. That is a 1.5-inch solid piece of stainless steel that is about 6 feet long (top). Another key to the straightening are two of these pucks (bottom) where the outside diameter fits snuggly under the axles bearing caps. The inside diameter is the same as the stainless steel rod. With the pucks installed in the axle, you can slide the rod through the axle and see how the axle needs to be bent the opposite way to straighten it. It turns out our axle was far from straight, despite its nice, thick axletubes. Tim couldn’t even slide the stainless rod all the way through our housing without straightening it first. So the next step is to lift the axle onto the straightening jig, which is basically a big piece of 1⁄2-inch thick I-beam steel with a cradle on one end, some huge chain, and a 20-ton jack. With the axle in the jig, you can begin to see how it works. A keen eye and experience determine how the axle is placed in the jig. The chain’s position is adjusted so that the jack can bend the axle opposite of the direction of the bend. This seems simple, but experience and knowledge of metallurgy is key here. Bend it too far, and you’ve made the problem worse or broken the housing. Once the axle is in the jig, it must be bent slightly past straight, so it returns to straight. One thing that Tim also did that helps the steel molecules find their happy place is to whack the axle with a big hammer a few times while it’s under tension. Once Tim had been working on the axle a little while, he noticed that the plug-welds to the cast centersection were tiny and some were cracked. This was allowing the axletube to move around in the housing, which was part of the problem with the axle. Tim also pointed out that if the axle’s inner knuckle is bent, they can’t straighten it, but chances are they can either replace the knuckle or help find a replacement housing. The fix for this is to straighten the axle in the jig, heat the housing with a torch, re-weld the plug welds, and weld the axletubes to the cast housing. Proper heating and slow cooling needs to occur for this to work properly. You can’t just weld the axletubes to the housing without heating the casting and then allowing it to cool slowly—in our case, while sitting in the Arizona sun on a 100-degree day. This makes our axle way stronger than it was with its tiny inadequate plug-welds. With a little work, our junkyard axle is better than we could have ever planned. Instead of being junk headed for the steel recycler, our junkyard axle is now better than ever. Arizona Differential charges a very reasonable $200 to $300 to straighten a front or rear axle, depending on how bad the axle is bent. Welding the axle like we did isn’t always necessary and brought our total repair to $350. Arizona Differential can also re-tube an axlehousing or build a custom axle from scratch. With their years and years of experience, wholesale prices, and huge inventory of used parts, your fix doesn’t have to cost a mint. Sources From: http://www.fourwheeler.com/how-to/transmission-drivetrain/1410-straightening-a-bent-dana-44-axle/#ixzz3Jk7eEXuA Follow us: @fwmag on Twitter | fourwheelermag on Facebook Link to comment Share on other sites More sharing options...
mnkyboy Posted November 21, 2014 Share Posted November 21, 2014 I've seen people straighten out D30s then put in an internal sleeve kit,its a cheap option that seems to work ok. Beyond that I would just build a different housing. Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 22, 2014 Author Share Posted November 22, 2014 Here from 4 wheeler how to straighten it: http://www.fourwheeler.com/how-to/transmission-drivetrain/1410-straightening-a-bent-dana-44-axle/photo-01.html To add on to the long line of “oops” moments we’ve had, we recently realized that a junkyard axle we grabbed, for what seemed like a steal, was bent. The plan was to build this cool full-width Ford F-150 high-pinion Dana 44 for one of our Jeep projects. The high-pinion design makes for great front driveshaft angles, and due to the nature of how a front axle turns relative to the gear, the high-pinion design means this axle is stronger than a low-pinion axle. Also, the tubes have a stout 1⁄2-inch wall thickness, so this axle should be difficult to bend. Or should have been difficult to bend; more on that in a minute. As plans changed and time passed, the axle spent way too much time sitting on jackstands in our garage, doing nothing but taking up space. We collected parts for a rebuild, and as our axle rebuild story’s due date was rapidly approaching, we dusted it off and started once again messing with the axlehousing. We had taken the axle down and had it sand blasted it some time back, and that makes working with it nice. Now, as we started working on the axle and used a plasma cutter to cut off the old axle brackets, we noticed a near-fatal problem with the axle: It was bent. It was hard to see the bend unless you stared at the axle for a while or peered down the axletubes. Poo. What now? Is it junk? Is it now only worth its weight in scrap steel? All our plans and parts collecting were for nothing—or so it seemed. Luckily for us, we had contact with a place that should be able to help us out. That place is Arizona Differential in Phoenix, Arizona. With one call, the owner, Nate, told us to drag our “slightly bent” axle down to him the next day. When we got there, Nate directed us to Tim Adkins who helped us straighten our axle that, as it turns out, had way more problems than we thought. In the end, our junkyard axle has a little bit more money invested in it, but its way stronger and probably straighter than the day it drove out of the Ford factory. Luckily for you, we also grabbed our camera and snapped a few pics to check show how the axle was straightened and strengthened. Instead of being junk headed for the steel recycler, our junkyard axle is now better than ever. Here is the axle. Can you see the bend? It’s subtle, but it’s there. It looks like maybe the Ford truck the axle came from was jumped and the axle bent in a very slight smile. Looking down the inside of the axle is the best way to see even a slight bend. If you line up the center of the two axle openings and the center is not perfectly inline, then your axle is bent. Unfortunately, it’s next to impossible to take a picture of this view, but see how the opposite opening looks egg shaped. Here, Tim shows us one part of the key to straightening an axle. That is a 1.5-inch solid piece of stainless steel that is about 6 feet long (top). Another key to the straightening are two of these pucks (bottom) where the outside diameter fits snuggly under the axles bearing caps. The inside diameter is the same as the stainless steel rod. With the pucks installed in the axle, you can slide the rod through the axle and see how the axle needs to be bent the opposite way to straighten it. Here, Tim shows us one part of the key to straightening an axle. That is a 1.5-inch solid piece of stainless steel that is about 6 feet long (top). Another key to the straightening are two of these pucks (bottom) where the outside diameter fits snuggly under the axles bearing caps. The inside diameter is the same as the stainless steel rod. With the pucks installed in the axle, you can slide the rod through the axle and see how the axle needs to be bent the opposite way to straighten it. It turns out our axle was far from straight, despite its nice, thick axletubes. Tim couldn’t even slide the stainless rod all the way through our housing without straightening it first. So the next step is to lift the axle onto the straightening jig, which is basically a big piece of 1⁄2-inch thick I-beam steel with a cradle on one end, some huge chain, and a 20-ton jack. With the axle in the jig, you can begin to see how it works. A keen eye and experience determine how the axle is placed in the jig. The chain’s position is adjusted so that the jack can bend the axle opposite of the direction of the bend. This seems simple, but experience and knowledge of metallurgy is key here. Bend it too far, and you’ve made the problem worse or broken the housing. Once the axle is in the jig, it must be bent slightly past straight, so it returns to straight. One thing that Tim also did that helps the steel molecules find their happy place is to whack the axle with a big hammer a few times while it’s under tension. Once Tim had been working on the axle a little while, he noticed that the plug-welds to the cast centersection were tiny and some were cracked. This was allowing the axletube to move around in the housing, which was part of the problem with the axle. Tim also pointed out that if the axle’s inner knuckle is bent, they can’t straighten it, but chances are they can either replace the knuckle or help find a replacement housing. The fix for this is to straighten the axle in the jig, heat the housing with a torch, re-weld the plug welds, and weld the axletubes to the cast housing. Proper heating and slow cooling needs to occur for this to work properly. You can’t just weld the axletubes to the housing without heating the casting and then allowing it to cool slowly—in our case, while sitting in the Arizona sun on a 100-degree day. This makes our axle way stronger than it was with its tiny inadequate plug-welds. With a little work, our junkyard axle is better than we could have ever planned. Instead of being junk headed for the steel recycler, our junkyard axle is now better than ever. Arizona Differential charges a very reasonable $200 to $300 to straighten a front or rear axle, depending on how bad the axle is bent. Welding the axle like we did isn’t always necessary and brought our total repair to $350. Arizona Differential can also re-tube an axlehousing or build a custom axle from scratch. With their years and years of experience, wholesale prices, and huge inventory of used parts, your fix doesn’t have to cost a mint. Sources From: http://www.fourwheeler.com/how-to/transmission-drivetrain/1410-straightening-a-bent-dana-44-axle/#ixzz3Jk7eEXuA Follow us: @fwmag on Twitter | fourwheelermag on Facebook Thank you so much! That helped a lot. Link to comment Share on other sites More sharing options...
