Pilot bushing
So I'm in the middle of swapping out the BA 10/5 for an AX-15 and came across a slight issue.....i went to but the new bushing in ( Dorman part# 690-042) and...it doesnt fit. So before i send it down to the machine shop at school to get cut down is there something I'm missing??
can you slide it on and off the input tip?  Did you keep the old bushing to compare to the new?  Did you remove the wick from the engine?  Just tossing out ideas.
I would recommend getting a caliper that can measure inside and outside diameters.  It is very handy.
Yes i know that it is, problem is that right now it is in my toolbox in a locked building. Yes the inner diameter fits the input shaft of the AX-15 and yes i have the outer part of the old pilot bearing that went with the BA 10-5 i just wanted to see if there was some trick to getting it in before i bring it down to the machine shop and have it turned down to match the old one. What do you mean the wick??
Thanks for the reply
If the ID is correct and the OD is correct, then I think you just need a hammer and big socket to drive it in.
The wick is a piece of cloth (or similar material) that is pushed in behind the PB.  It may not be in yours.  It is soaked in oil and keeps the PB lubricated.
Unfortunately i don't have the time to wait to get another one, i can't have it sitting in the way taking up lab space at school for another few days. how did you get a tj bushing to fit Blue XJ? Arent the sizes different for the renix to the newer 4.0?
I am only aware of the ID changing from ~.5" to ~.75"
You may have the wrong PB.  Go to your local auto parts store and get one there.  Take with you both the original and the replacement one.
Good luck.  Without being there to look at it, I cannot think of anything else.
Well I figure there's a machine shop on campus so I might as well take advantage of it and have a professor turn it and take off the few thousands that's needed. And while I wait on that I'm getting everything else done
I'm not sure, it was from a TJ though, actually a bearing too, had needle bearings in it, not just a bronze bushing. My crank had two diameter pilots on the rear, I used the bearing that fit in the larger outer one.
You know what, disregard my post, I have a stroker, I'm running a 258 crank.
  • 3 weeks later...
