badazzelanore Posted November 6, 2014 Share Posted November 6, 2014 I just pulled my sending unit/fuel pump out to replace the pump. The fuel hose in the sending unit is deteriated and crumbled when i pulled it out. Anyway i want to drop the tank and make sure it is clean but it started raining here really hard so here are my questions. 1. Will humidity get in the tank and rust it? 2. Whats my best option for sealing up the hole? I was just going to put some duct tape or painters tape over the hole. Link to comment Share on other sites More sharing options...
ScottJeep Posted November 7, 2014 Share Posted November 7, 2014 RockAuto new tank. Cheaper in the long run. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 7, 2014 Share Posted November 7, 2014 Why monkey around with a broken 25 year old tank when you can get a new tank for less than $150? Fix the problem the right way the first time. Then spend your time on something else! Link to comment Share on other sites More sharing options...
Pete M Posted November 7, 2014 Share Posted November 7, 2014 you can probably just shove a clean rag in the hole and call it good. :thumbsup: a bit of humidity won't hurt it. just run a can of gas-drier in the first tank of fuel if you've worried. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 7, 2014 Share Posted November 7, 2014 you can probably just shove a clean rag in the hole and call it good. :thumbsup: a bit of humidity won't hurt it. just run a can of gas-drier in the first tank of fuel if you've worried. Now I get it! He was just worried about humidity while the sender was out of the tank. Dah...That is not a problem when you spend all your life in Southern California! Put the tank in a large plastic lawn bag, that should solve the problem or just cover the tank with plastic. Or put the tank in the garage if you have one. Link to comment Share on other sites More sharing options...
badazzelanore Posted November 8, 2014 Author Share Posted November 8, 2014 Lol i can understand the confusion, thanks for the responses. The tank is still under the truck. I just shoved a large rag in it and called it good. The next step is to take the fuel tank off and get into the garage so I can clean it out. I am thinking about using the por 15 fuel tank sealer. What do y'all think? Link to comment Share on other sites More sharing options...
Pete M Posted November 8, 2014 Share Posted November 8, 2014 is your tank leaking? Link to comment Share on other sites More sharing options...
badazzelanore Posted November 10, 2014 Author Share Posted November 10, 2014 No not leaking, I mean it leaked when I pulled the fuel sending unit out... tank had close to 15 gallons in it and my driveway is on a pretty good slope lol. Luckily i happened to have a plastic storage bucket within arms reach to catch 90% of what leaked out. Then i siphoned out the rest of the tank. I plan on pulling the tank off Tuesday or Wednesday if the weather is as nice as it has beem the last couple of days. I just want to seal the fuel tank so i don't have to fool with it again. Link to comment Share on other sites More sharing options...
Pete M Posted November 10, 2014 Share Posted November 10, 2014 unless it's crazy rusty or damaged, you really shouldn't need to do anything to it. :thumbsup: Link to comment Share on other sites More sharing options...
badazzelanore Posted November 10, 2014 Author Share Posted November 10, 2014 10-4. I just live in the gulf coast of south Texas. 5 min from a Padre Island. So rust may eventually be a problem. Should I just por-15 the outside? Link to comment Share on other sites More sharing options...
Minuit Posted November 10, 2014 Share Posted November 10, 2014 Like Pete said, if it doesn't have holes in it and doesn't leak you shouldn't have to do anything. Por-15 would prevent the outside from rusting if you want to do it, though. Link to comment Share on other sites More sharing options...
Pete M Posted November 10, 2014 Share Posted November 10, 2014 I've had some insanely rusty MJs pass through my hands and none of them had leaks in the fuel tank. Link to comment Share on other sites More sharing options...
badazzelanore Posted November 12, 2014 Author Share Posted November 12, 2014 Tank looks fine. No leaks. I think ill por-15 the outside as cheap insurance. Link to comment Share on other sites More sharing options...
Minuit Posted November 13, 2014 Share Posted November 13, 2014 I've had some insanely rusty MJs pass through my hands and none of them had leaks in the fuel tank. Interesting - mine had a hole in it when I got it. Practically rust-free otherwise. Link to comment Share on other sites More sharing options...
mikejenn2 Posted November 13, 2014 Share Posted November 13, 2014 a little off subject, but if the gas fell on a tar driveway keep in mind it will eat it up and turn the area into powder. may want to seal it up b4 it does. Link to comment Share on other sites More sharing options...
