ScottJeep Posted October 10, 2014 Share Posted October 10, 2014 Yeah, not really trying to start a theme with my posts.... but have noticed as the weather has started to change many of us are dealing with Heat-A/C issues and many appear to be vacuum canister related. In the rebuilding of my latest MJ, the vacuum canister was one of the missing items. My solution thus fare was grab a small Vacuum Ball from the Jeep parts bin/cabinet in the garage which is the size of....a large grapefuit. But normally I think the MJs and XJs had a somewhat larger canister behind the bumper on the passenger side. I've also wonder about the newer canisters.... Since mine was MIA. I've also relocated the ball up into the engine compartment just to make it easier regarding routing vacuum hoses etc. Does the SIZE on these things matter or make a difference and is there really a WRONG way to connect to the things? Thanks in advance. Link to comment Share on other sites More sharing options...
thejim42 Posted October 10, 2014 Share Posted October 10, 2014 I know my 88 has the smaller one. My 86 had the bigger one but it had a/c and cruise control which from what I read is the reason for the bigger canister. That's all I really know about them. I hope that helps Link to comment Share on other sites More sharing options...
Rockfrog Posted October 10, 2014 Share Posted October 10, 2014 My 88 MJ, 5spd non A/C has the smaller one. My 00 XJ, Auto with A/C has the exact same one. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted October 10, 2014 Share Posted October 10, 2014 My MJ has a grapefruit. I have no cruise. My XJ has a football, it has cruise. The only "trick" to installing it is...the fat hose goes to the port that says "vac". The skinny hose in the other port on the grapefruit. On the football there is a set of ports on each end, the fat hose has a T in it that goes to either end. I had always thought the other end went to cruise...but not sure since others have said they have cruise and a grapefruit. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted October 10, 2014 Share Posted October 10, 2014 my 1988 4.0 5-speed with AC has the football Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 10, 2014 Share Posted October 10, 2014 I don't think size matters too much (in this case :yes: ). I installed a small cannister from a Porsche in the engine compartment and got rid of the football behind the bumper. The cruise and the rest of the vacuum controls work just as well with the smaller reservoir as it did before. Link to comment Share on other sites More sharing options...
ARareBreed Posted April 11, 2017 Share Posted April 11, 2017 I want to put in a grapefruit reservoir, but there are multiple ports on it compared to my singular port football. Should I plug up the unnecessary ports on the grapefruit reservoir if I get one? Edit**** Or I can get a Dorman 47077 canister and call it a day? Link to comment Share on other sites More sharing options...
omega_rugal Posted April 12, 2017 Share Posted April 12, 2017 the larger can hold more "vacuum action" than the small one, that`s all... Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 14, 2017 Share Posted April 14, 2017 the larger can hold more "vacuum action" than the small one, that`s all... The round ball has one chamber. The football shaped ball has two chambers, separated from each other by a "wall" in the middle. Thus the vac ports on either end. I don't know what the thinking was when they moved to the football shaped one. I would think that one side was dedicated to cruise and the other to HVAC. Link to comment Share on other sites More sharing options...
ARareBreed Posted April 14, 2017 Share Posted April 14, 2017 the larger can hold more "vacuum action" than the small one, that`s all... The round ball has one chamber. The football shaped ball has two chambers, separated from each other by a "wall" in the middle. Thus the vac ports on either end. I don't know what the thinking was when they moved to the football shaped one. I would think that one side was dedicated to cruise and the other to HVAC. My football only has one port but my MJ didn't have cruise from the factory - interesting. I wonder If I can get away with the round ball with one port now that I installed factory cruise... Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 14, 2017 Share Posted April 14, 2017 I had cruise on my 91 for years using the round factory canister - no problems ever. But I didn't use cruise all that much either. As long as your vacuum system is free of leaks and the check valves work properly you will be fine. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 17, 2017 Share Posted April 17, 2017 ^^^^ Yup! Link to comment Share on other sites More sharing options...
