Dirteatr717 Posted September 26, 2014 Share Posted September 26, 2014 So I've replaced the headlight dimmer switch in the dash 2 times in the past 6 months, the headlight switch 2 months ago and lost my head lights last week and havent had time to play with them.. after taking out the headlight switch and finding out it was fine i swapped out the dimmer switch in the dash with a spare one 5 minutes ago and now I don't have working wipers.. I tried looking to see if I disconnected anything but its been a long day and I don't know what else is involved in the electrical side of the wipers.. Any suggestions? They worked fine the other day :burnsjeeptoground: Link to comment Share on other sites More sharing options...
Blood of a Jeep Posted September 26, 2014 Share Posted September 26, 2014 Did you perhaps bump the big silver fuse/relay at the bottom of the fuse block? Mine didnt work til i wiggled that, found the contacts were spread open. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 26, 2014 Author Share Posted September 26, 2014 It's quite possible, ill wiggle it later and see what happens. What else should I check? Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 26, 2014 Share Posted September 26, 2014 Failed ground somewhere is my guess. Link to comment Share on other sites More sharing options...
Guest Posted September 27, 2014 Share Posted September 27, 2014 Failed ground somewhere is my guess. This. I would check the wiring behind the lights in the front clip. I ended up having a similar problem with my parking lights, only to find that the original sockets for the lights had rusted out pretty bad (OE sockets were cylindrical POS Ford-types), shorting out my connections to the dash lights. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 27, 2014 Author Share Posted September 27, 2014 The lights aren't my problem anymore it's the lack of wipers! They worked fine before I unplugged the high/low switch on the column and then changed out the dimmer switch in the dash and and put it all back together only to not have working wipers. Since there isn't a fuse for them and the wiper module looks to be okay what else should I check... I'm going camping up at American fork canyon and its supposed to rain and snow all weekend.. Link to comment Share on other sites More sharing options...
gogmorgo Posted September 27, 2014 Share Posted September 27, 2014 There's a 5.5A circuit breaker for the wipers on the fuse box, probably what BloodofaJeep is talking about. Number 15 in this diagram, on the left side. Did you by chance unplug the wiper switch connector, located on the steering column? There are at least two long flat connectors on the steering column. The shorter of the two is for the wiper switch. The really long one is for the turn signal switch. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 27, 2014 Author Share Posted September 27, 2014 I found the 7 wire white flat connector but can't find the other connector for it? And my 5.5 amp breaker is stuck in the fuse panel. Anyone have pictures? I know it's tight in there but pics would help out a lot Link to comment Share on other sites More sharing options...
cruiser54 Posted September 27, 2014 Share Posted September 27, 2014 Anything else not work? Like turn signals, blower motor etc? Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 28, 2014 Author Share Posted September 28, 2014 Got the breaker out and went to 3 parts stores and none of them had any :( everything else works fine. I ended up just getting some rainx and saying screw it and drove over 200 miles yesterday without wipers in the rain.. That was fun Link to comment Share on other sites More sharing options...
cruiser54 Posted September 28, 2014 Share Posted September 28, 2014 Those breakers are as common as belly buttons!! Did you ask at the counter or go to the fuse section? Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 28, 2014 Author Share Posted September 28, 2014 Both! Went to a Autozone, napa and car quest and nobody Behind the counters has "never seen something like that" I was just going to file the edges of a 10a big fuse and see if that did anything.. Link to comment Share on other sites More sharing options...
