Blue88Comanche Posted September 17, 2014 Share Posted September 17, 2014 I bought a new radiator for the MJ and it has the auto trans cooler, but I don't need it because I have the 5 speed. What are some clever uses I could use the auto trans cooler for? Link to comment Share on other sites More sharing options...
Lee21490 Posted September 17, 2014 Share Posted September 17, 2014 I bought a new radiator for the MJ and it has the auto trans cooler, but I don't need it because I have the 5 speed. What are some clever uses I could use the auto trans cooler for? Probably not much. Maybe boil some water in it & make a cup of tea. Link to comment Share on other sites More sharing options...
COFFMAN Posted September 17, 2014 Share Posted September 17, 2014 Power steering cooler :thumbsup: Link to comment Share on other sites More sharing options...
Blue XJ Posted September 17, 2014 Share Posted September 17, 2014 Power steering cooler :thumbsup: That was my thought as well, although I would never use it for that purpose. Other than steering, there really isn't any fluids under the hood to keep cool. Link to comment Share on other sites More sharing options...
valis Posted September 17, 2014 Share Posted September 17, 2014 CPU cooler Link to comment Share on other sites More sharing options...
BIGHEEP Posted September 17, 2014 Share Posted September 17, 2014 Route your washer fluid through it? :) Link to comment Share on other sites More sharing options...
Blue88Comanche Posted September 17, 2014 Author Share Posted September 17, 2014 this explains why google did not have much to say on this topic lol Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 17, 2014 Share Posted September 17, 2014 Power steering cooler :thumbsup: That was my thought as well, although I would never use it for that purpose. Other than steering, there really isn't any fluids under the hood to keep cool. I've read about guys doing just that on rock crawlers, but when taking fluid temps before and after, running the power steering fluid through the radiator cooler actually made the fluid hotter than w/o it. So probably not a good idea. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 17, 2014 Share Posted September 17, 2014 Nothing. Why put another fluid through something with potential failure leading to direct contact and contamination with coolant? I add a separate cooler to every auto car I own and remove it from the radiator completely. Takes longer to warm the trans in winter, bit I'm good with knowing it won't puke the trans from a bad radiator. Link to comment Share on other sites More sharing options...
COFFMAN Posted September 18, 2014 Share Posted September 18, 2014 My mistake did not read the post correctly. I'm using my original XJ trans cooler ( the little in line one ) for my power steering cooler. As I fitted a bigger inline trans cooler bypassing the radiator. So yep them ports in your radiator are probably go for sweet &%#@ all. Link to comment Share on other sites More sharing options...
dankicksass Posted September 18, 2014 Share Posted September 18, 2014 My new radiator has dual transmission coolers for LHD or RHD, not sure if I'll actually use both of them but it's nice to have options. Since my trans lines are pretty much ruined, I'll probably use the RHD side when I plumb it to save routing length. Only other fluids underhood that could benefit from cooling are oil and power steering, but only if you really go hard. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 18, 2014 Share Posted September 18, 2014 Dan, ditch the rad cooler and go full external. You will thank me Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 18, 2014 Share Posted September 18, 2014 I used the radiator cooler and a factory external cooler for the tranny. Works great. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 18, 2014 Share Posted September 18, 2014 Dorman 918-251 . Trans cooler Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 18, 2014 Share Posted September 18, 2014 Dorman 918-251 . Trans cooler Cool. Didn't know Dorman made this. :cheers: Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 18, 2014 Share Posted September 18, 2014 I've got one on the white truck and an NOS modine one on the black truck . Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 18, 2014 Share Posted September 18, 2014 I have the Modine one. Did you plumb it into the return line? I tried both ways and in taking temps over a period of time it cooled better using the return line. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 18, 2014 Share Posted September 18, 2014 Yep I used the remnants of one of the old trans lines and plumbed it all together . I never did check any trans fluid temp though. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 19, 2014 Share Posted September 19, 2014 I used the radiator cooler and a factory external cooler for the tranny. Works great. However, you are not going to be off-roading it, and aside from the extra heat from the stroker and potential chance of overheating, your system is in far more efficient condition. Any offroad vehicle has increased chance of non-heat related damage. Last thing I want in those situations is to crack a radiator, have to limp it off the trails, and find that I also contaminated $60 worth of ATF, if not wrecking the trans Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 19, 2014 Share Posted September 19, 2014 I used the radiator cooler and a factory external cooler for the tranny. Works great. However, you are not going to be off-roading it, and aside from the extra heat from the stroker and potential chance of overheating, your system is in far more efficient condition. Any offroad vehicle has increased chance of non-heat related damage. Last thing I want in those situations is to crack a radiator, have to limp it off the trails, and find that I also contaminated $60 worth of ATF, if not wrecking the trans All true and understand your point. I stuck the external tranny cooler in only because I towed a bike trailer with it quite a bit for awhile. I think an external tranny cooler is good to have in any MJ. In colder climates the rad cooler helps warm up the fluid faster, probably the biggest reason it's there. But for warmer climates, the rad cooler isn't really necessary as long as a decent external cooler is plumbed in. Link to comment Share on other sites More sharing options...
