waggy front end on mj3800
JeepcoMJ
picked up a waggy front end today
i cleaned everything, taped it all off,a nd painted the centers of the headlight bezels and grille black. also painted the turn signals
and i kinda test fit it
so now i gotta sand it, prime it, wet sand it, then thin the spare paint i have from when i got my truck painted, and spray the crap outta it so it will match, then clear coat it.
hopefully i can do all the sanding and stuff by tomorrow, and then paint it a couple coats, then have it done after work on sunday night...bolt it on and voila!
i got the wiring too, but it's all the same except the headlight wires...i'm going to use my existing harness and make a connector plugin to split the old headlight connector into the dual connectors. should be a sinch :D
I like it, the first one I saw was when somone posted a pic on JU back in 99. At the time not many liked it, it even had the woody sides installed like the old Ford Ranchero or Chevy El Camino Woody's of the 70's and early 80's. I am not too fond of the Woody sides but that front end is sweet. So far there are two options for us the 97+ front clip or this one. I am researching a distant third possibility, and that is a front clip install from the Chinese 2500 XJ. A friend of mine is an immigrant from mainland China, and goes back every couple of years. He tells me He can get those parts and ship them back, but my fear is paying for two fenders, lights, markers, bumper and header only to find it won't work with the MJ. When I find out what those parts cost I will keep everyone posted. :popcorn:
  Mitch said:
I thought you were putting a 97+ face on the 3800 and building a different MJ with the waggy nose?
Thought I read that like yesterday... could have been someone else I guess..
no you probably read right. JeepCo thinks a mile-a-minute and changes MJ plans like some chang their underwear
haha, that was me but after getting it and setting it on the truck, i just GOTTA do it. this was cheaper and less people have done it :D
haha, thanks colton!
not a problem, friend lol
  Oizarod115 said:
i think it'll look bad man!
but if your truck or the other one has been wrecked they may not line up exactly flush first try.
nothin wrecked. bad or badass? :P
if it don't look good i can always put the old one back on...it was cheap so whatever :P
bad-@$$. lol
idk how itll fit, my trucks been wrecked fornt end (two times i think) and the header panel i got had been through a fender bender
so mine doesnt line up EXACTLY but its not to bad. but you like things to be 'right' so i figured i'd mention it
are you calling me uptight?
haha, i do want it to be perfect as possible.
that will be different with the incoming truck...it's not gonna be halfass, but it won't be perfect either...i want it for a DD and for my wheeling truck, so scratches dings and nicks are for character.
well when you put that much work into that engine/rest of the truck :bowdown: ... i wouldnt want a cockeyed header panel either. :brows:
  Pete M said:
I wonder what it would look like with the waggy lights and the MJ grille? :hmm:
i wondered that too.
here's the problem...the waggy grille is about 4 inches longer than the mj grille. so nothing would work...
oh, and the waggy grille has the turn signals built into it...soo that would have to happen to the manche grille.
basically, not possible without some cutting and serious plastic welding.
  Pete M said:
bummer.
yup, if it were otherwise, i would just put the waggy grille on my manche, hook up the waggy turn signals, remove my turn signals, and put fog lights in place of them...kinda like what you did Pete, except with waggy turn signals.
come to think of it...i'm going to do some more measuring. perhaps If the mounts are spaced the same i can cut some out of the middle of the grille and screw it in????
that would be the tits
