I promised Matt that I wanted the utility bed and would be up and get it. Unfortunately I'm unable to make it. It seems the ol bod after 79 years of use, misuse, and abuse 'ain't taking it no more' and has crapped out on me.. I'm just not functioning. Anyway would somebody please save this bed? I already called Matt and told him I wouldn't be up for it so it's available. This is to rare of a part to go for scrap. Jimbo
I could pick it up on Saturday afternoon if it is still available. Would it fit in the back of a f150? If not it could complicate things.
If you set it on its side it would fit, or place a couple 2X4's across the bed rails for it to set on. Have Matt measure how tall the sides are? See if it will fit.
Flip upside down, set on bedrails, strap like a mofo.
If we could figure out how to get it from there to wi, I would compensate for it. Just can't get the time to come for it.
I'm still interested in picking it up. I thought about it and figured I could set it on it's side and strap it good. My only secure anchors are inside the bed.
I will be there Saturday afternoon. I will be able to firm up the time tomorrow (Fri. 29th) evening. Does that work for whoever is involved?
See the ladder rack posts? Put 4x4s across your bed from side to side, set this down upside down, and hook 4 straps to those posts and your tie downs. Would work perfect.
Jim,
I hope its just a bump in the road, and whatever ails you improves.
You seem more alive than most teenagers I know so I hope your heath gets better
good luck
  • 10 months later...
