oil weight ?
  • 3 weeks later...
what kind is the 4.0 made to take?
The old ones were supposed to use 10W30 or 10W40 (both were listed in the FSM). The newer ones are supposed to use 5W30
well i got 213K on the motor and do alot of higher rpms (3,500+)
will 10w-30 work fine or synthetic?
How's your oil pressure? If you're getting 40 psi or better at highway speed with the 10W30, it's okay. Personally, on a high mileage engine I would be using 10W40 or a wider range synthetic. In my '88 XJ I'm at 265,000 miles and I run Castrol 5W50 in the winter, 20W50 in the summer.
And you shouldn't be running a 4.0L above 3,500 RPM a lot. Especially not an '88. The torque peak is WELL below that. You're just beating up the engine for no purpose. I doubt that mine ever goes above 3,500 RPM. My normal shift point is 2,200 RPM.
