88ComancheMitch Posted July 3, 2014 Posted July 3, 2014 Maybe this will be a sticky eventually, but I didn't see a topic that had everything in one place that would let you see some swappable parts from various vehicles. I'll kind of start a template...the idea is to have a list of stuff that can be directly, or almost directly, swapped. Hopefully I didn't miss this sticky/section somewhere. Some applicable information. Some has been repeated. Cherokee Junkyard and Budget Jobs Suspension Lift: ZJ coils lift approx 1-2" in the front F150 coils lift approx 3" in the front, but will cause a stiff ride. Spring over axle swap in the rear lifts between 5-7" (wide variance here) For extended brake lines, large dodge ram vans from the same era will fit. TJ Coils fit, but will provide 1" less lift than what is specified (I.e. stock springs = 1" drop, 3 inch TJ coils = 2 inch MJ coils) General Better ride and wheel clearance with WJ LCA's (UCA's will fit, but only give the benefit of a better ride to my knowledge) Driveline: Rear Axle Cherokee rear ends require spring perch relocation, but the D35 and Chrysler 8.25 fit Ford 8.8" will fit, and have commonly sought after gearing (3.73, 4.10, etc) and typically have disc brakes and posi-traction. (Will require spring perch relocation, 1" wheel spacers) Brakes: WJ Brake booster/Master Cylinder. Upgrades braking--Must be done together. YJ brake lines (3-4" longer) WJ Rotors and Calipers (Larger, most stopping power, check fitment with rims) Can convert from drum to disk using ZJ parts. Need everything from the backing plates out. Suggest using brake booster and master cylinder. Dakota ('95-'00) Rear soft brake lines. 6" Longer K1500/GMC Front softlines-require some modification ('90-'95) 6" Longer KJ Disc brakes can be used to convert For extended brake lines, see lift section.
dasbulliwagen Posted July 4, 2014 Posted July 4, 2014 There's a thread on naxja called junkyard upgrades that has tone of info like this. I would link to it but am on my phone right now. Good stuff!
Incommando Posted July 4, 2014 Posted July 4, 2014 The dual diaphragm upgrade is worth its weight in gold
benjy_26 Posted July 4, 2014 Posted July 4, 2014 95 C1500 brake hoses work for 5 inches of lift in the front with a bit of grinding. ZJ steering box has a quicker ratio and bolts in ZJ V8 Tie rod bolts in ZJ aux tranny cooler makes for a dandy P/S cooler ZJ spring isolators have a metal core and are stackable. Good for a cheeeeaaap budget boost or for leveling a rig from side to side The zj 44A isn't as sought after as the 8.8, but I think if one is building a street 'Manche or keeping the tire size sane, it would make for a strong (enough), cheap, plentiful upgrade that is the right width and comes with discs to boot that is significantly lighter than the 8.8.
Incommando Posted July 4, 2014 Posted July 4, 2014 The D44a is not a desired piece and has limited aftermarket support. I have read of guys replacing them with 8.25's....
benjy_26 Posted July 4, 2014 Posted July 4, 2014 The D44a is not a desired piece and has limited aftermarket support. I have read of guys replacing them with 8.25's.... Not every peg fits every hole... I agree, the aftermarket SUCKS for the 44A. BUT with the proper truss to alleviate the flexing issues, it should be a pretty strong axle. It has a beefier R&P set up than a regular 44, IIRC. One can also get decent gears for it, up to 4.56's I think. I stand by my statement.
88ComancheMitch Posted July 4, 2014 Author Posted July 4, 2014 More than one way to skin a cat. Sometimes whats available is whats best. Awesome information guys. Keep it coming
yxmj Posted July 4, 2014 Posted July 4, 2014 I had this cut an pasted from somwere.... Suspension & Lift:1. ZJ V8 Upcountry Coils = 1-1.5" lift2. F-150/Bronco Coils ('70s-ish) = 4-4.5" lift3. S10 (P/U or Blazer) leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift (may require use of degree shims)4. Dakota Bastard Pack (do same as with S10 pack) = ~4" lift5. JK shocks = slight mod to fit 2-4" lift (some dispute)6. MJ Shackles = 1/2" lift7. Camaro Spring Isolators = 1.5" lift8. Full size Blazer Bastard Pack (do same as S10 pack) = 4-4.5" lift (may require use of shims) may be stiffer than S10 leafs9. ZJ spring isolators = stronger, metal core, can be stacked10. GM fullsize pickup shackles ('95-99) = 1.5" lift, better shackle angle11. Thunderbird Front Coils ('83-97) = 3-4" lift (varies in lift and softness by year and trim package), will need top plate from strut too12. Any 2.5" wide leaf spring can be used between to make a bastard pack (they may differ in stiffness and lift)13. S10 Shocks (Rear only) = good for the lift you will get when you do a bastard pack14. TJ Lift Coils (front only) = provide 1" less lift on an XJ than on a TJBrakes:1. WJ brake booster2. WJ Master Cylinder3. YJ Brake Lines = 3-4" longer4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts)5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims)6. ZJ brake booster, master cylinder, proportioning valve = may need for disc conversion7. XJ '95+ brake booster and master cylinder = dual diaphragm8. Dakota Rear Softlines ('95-00) = 6" longer9. GM C/K1500 Front Softlines ('90-95) = 6" longer10. KJ disc brake set-ups can be used for a conversion on your XJ axleAxles:1. Ford 8.8 inch ('97+) = need spring & shock mounts (3.55, 3.73, or 4.10, maybe LSD, Disc Brakes)2. XJ I-4 & some V6 = may have 3.73, 4.10, or 4.56 gears may have vacuum discos3. XJ C8.25 ('97+) = bolt in and upgrades to 29 spline (strength comparable to D44)4. XJ D44 = found in some but not all '87-'89 XJ's with Towing Package5. Lincoln Lockers = welded spider gears, operates like a spool, must be a GOOD welder6. MJ D44 = need new spring perches and shock mounts7. XJ D30 = ('95-'99) non-disconnect, larger u-joints, high pinion, bolt in8. Homebrew posi-locks for '84-90 vacuum disconnect D30s, eliminates vacuum actuation (use search function)Front End & Steering:1. ZJ V8 Tierods = beefier & bolt in2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering3. Durango Steering Box = beefier4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding)5. WJ LCA's = more tire clearance (some grinding required)6. ZJ pitman arm = 1 inch drop over stock7. WJ rear LCA's = replace XJ front LCA's, 2" longer to accommodate a lift, some grinding required8. WJ power steering pump (fits '96+, plug return hole, and use XJ pulley)9. V8 ZJ front sway-bar10. JK rear UCA = use as XJ LCA, its about 1-2" longerEngine/Transmission/T-case:1. Newer XJ intakes (may require some modification)2. Mustang 5.0 Injectors = near bolt in (have 4 holes instead of 1, more fuel, better spray)3. ZJ V8 alternator = more power to run accessories (some grinding required) 136A (for 1991 and newer XJ's).4. Ford Electric Fan ('90-95 3.8L Taurus, '87-93 5.0L Mustang) = replaces mechanical fan, more cooling (8C607)5. 2.5L Dakota Alternator = bolt in, upgrades to 117A6. Dodge Neon Injectors = better throttle response 7. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing)8. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style)9. 5spd crossmembers give 3/4 inch t-case drop on autos with no loss in ground clearance10. Hoodvents (i.e. Lebaron, Laser, Turbo Thunderbird etc.) = help keep ur 4.0 cool at low speeds11. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an MJ overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core.12. Homebrew Slip Yoke Eliminator (use search function)Body/Interior/Armor:1. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails.2. MJ/2 Door XJ Bucket seats = tilt forward, bolt in3. ZJ gas tank skid = can be modified to fit 97+4. GM power antennas replace your broken XJ's with little modification5. XJ '97+ doors onto older cherokees = one piece windows and better mirrors6. XJ overhead console = most commonly found in '00-01 or higher trim level, provides space for switches etc.7. '97+ center console = can be made to fit '96 and older, gives you cupholders!8.'96-00 Ford Explorer hatch shocks = lift your hatch about 3" lower but are beef (ever see one that doesn't work?) need modification for '97+9. OEM skid plates (Front, Tranny, T-case, gas tank, found on "up-country" package XJ's)10. OEM swing-out tire carriers, get the bumper with it, found mainly on '84-'90 XJ's
88ComancheMitch Posted July 4, 2014 Author Posted July 4, 2014 I had this cut an pasted from somwere.... Suspension & Lift: 1. ZJ V8 Upcountry Coils = 1-1.5" lift 2. F-150/Bronco Coils ('70s-ish) = 4-4.5" lift 3. S10 (P/U or Blazer) leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift (may require use of degree shims) 4. Dakota Bastard Pack (do same as with S10 pack) = ~4" lift 5. JK shocks = slight mod to fit 2-4" lift (some dispute) 6. MJ Shackles = 1/2" lift 7. Camaro Spring Isolators = 1.5" lift 8. Full size Blazer Bastard Pack (do same as S10 pack) = 4-4.5" lift (may require use of shims) may be stiffer than S10 leafs 9. ZJ spring isolators = stronger, metal core, can be stacked 10. GM fullsize pickup shackles ('95-99) = 1.5" lift, better shackle angle 11. Thunderbird Front Coils ('83-97) = 3-4" lift (varies in lift and softness by year and trim package), will need top plate from strut too 12. Any 2.5" wide leaf spring can be used between to make a bastard pack (they may differ in stiffness and lift) 13. S10 Shocks (Rear only) = good for the lift you will get when you do a bastard pack 14. TJ Lift Coils (front only) = provide 1" less lift on an XJ than on a TJ Brakes: 1. WJ brake booster 2. WJ Master Cylinder 3. YJ Brake Lines = 3-4" longer 4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts) 5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims) 6. ZJ brake booster, master cylinder, proportioning valve = may need for disc conversion 7. XJ '95+ brake booster and master cylinder = dual diaphragm 8. Dakota Rear Softlines ('95-00) = 6" longer 9. GM C/K1500 Front Softlines ('90-95) = 6" longer 10. KJ disc brake set-ups can be used for a conversion on your XJ axle Axles: 1. Ford 8.8 inch ('97+) = need spring & shock mounts (3.55, 3.73, or 4.10, maybe LSD, Disc Brakes) 2. XJ I-4 & some V6 = may have 3.73, 4.10, or 4.56 gears may have vacuum discos 3. XJ C8.25 ('97+) = bolt in and upgrades to 29 spline (strength comparable to D44) 4. XJ D44 = found in some but not all '87-'89 XJ's with Towing Package 5. Lincoln Lockers = welded spider gears, operates like a spool, must be a GOOD welder 6. MJ D44 = need new spring perches and shock mounts 7. XJ D30 = ('95-'99) non-disconnect, larger u-joints, high pinion, bolt in 8. Homebrew posi-locks for '84-90 vacuum disconnect D30s, eliminates vacuum actuation (use search function) Front End & Steering: 1. ZJ V8 Tierods = beefier & bolt in 2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering 3. Durango Steering Box = beefier 4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding) 5. WJ LCA's = more tire clearance (some grinding required) 6. ZJ pitman arm = 1 inch drop over stock 7. WJ rear LCA's = replace XJ front LCA's, 2" longer to accommodate a lift, some grinding required 8. WJ power steering pump (fits '96+, plug return hole, and use XJ pulley) 9. V8 ZJ front sway-bar 10. JK rear UCA = use as XJ LCA, its about 1-2" longer Engine/Transmission/T-case: 1. Newer XJ intakes (may require some modification) 2. Mustang 5.0 Injectors = near bolt in (have 4 holes instead of 1, more fuel, better spray) 3. ZJ V8 alternator = more power to run accessories (some grinding required) 136A (for 1991 and newer XJ's). 4. Ford Electric Fan ('90-95 3.8L Taurus, '87-93 5.0L Mustang) = replaces mechanical fan, more cooling (8C607) 5. 2.5L Dakota Alternator = bolt in, upgrades to 117A 6. Dodge Neon Injectors = better throttle response 7. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing) 8. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style) 9. 5spd crossmembers give 3/4 inch t-case drop on autos with no loss in ground clearance 10. Hoodvents (i.e. Lebaron, Laser, Turbo Thunderbird etc.) = help keep ur 4.0 cool at low speeds 11. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an MJ overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core. 12. Homebrew Slip Yoke Eliminator (use search function) Body/Interior/Armor: 1. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails. 2. MJ/2 Door XJ Bucket seats = tilt forward, bolt in 3. ZJ gas tank skid = can be modified to fit 97+ 4. GM power antennas replace your broken XJ's with little modification 5. XJ '97+ doors onto older cherokees = one piece windows and better mirrors 6. XJ overhead console = most commonly found in '00-01 or higher trim level, provides space for switches etc. 7. '97+ center console = can be made to fit '96 and older, gives you cupholders! 8.'96-00 Ford Explorer hatch shocks = lift your hatch about 3" lower but are beef (ever see one that doesn't work?) need modification for '97+ 9. OEM skid plates (Front, Tranny, T-case, gas tank, found on "up-country" package XJ's) 10. OEM swing-out tire carriers, get the bumper with it, found mainly on '84-'90 XJ's This is the first link I have up there. I'm going to start updating the original post as I have time.
88ComancheMitch Posted July 4, 2014 Author Posted July 4, 2014 Anyone know if the 5 speed t case drop works on Comanches?
yxmj Posted July 4, 2014 Posted July 4, 2014 Sorry :dunno: Links were not working for me....oh well....can't have enough info :thumbsup:
Spectormj Posted July 4, 2014 Posted July 4, 2014 I'm getin tj coils tomarrow ill post up a pic once they are in
Spectormj Posted July 4, 2014 Posted July 4, 2014 ill find out tomarrow but i think it just is an inch under what it will lift a tj
benjy_26 Posted July 4, 2014 Posted July 4, 2014 Ah... TJ lift coils? Yeah. If you get 3" TJ coils they're 2"s on an MJ.
pettus253 Posted July 7, 2014 Posted July 7, 2014 Will I need to change out my transmission if i'm converting from 2wd to 4x4? 1990 2wd 2.5L. Have axles out of a 99 XJ.
Incommando Posted July 7, 2014 Posted July 7, 2014 With the 4.0 drivetrain you would need to either get a 4wd tranny (easier) or convert your 2wd output to 4wd (harder). I am fairly certain that it is the same with the 4cyl's trannies.
