Swapping 96 Cherokee To 86 Comanche
Hi folks, I am in the process of making sure I have everything lined up for the upcoming swap. Will be taking the drivetrain(4.0L + AW4 + NP242) along with dash and full wiring harnesses except for body wiring, from a 96 XJ over to my 86 MJ. Also swapping over wil be the front doors, front axle and driveshafts as the front will be bolt in and the rear I will either have to shorten the current shaft or lengthen the cherokee shaft. I have been going over the wiring schematics and doing a lot of measuring, between both vehicles.  Would like any input in case there may be something I am overlooking in regards to the swap. Anything you may have run into, had an issue with proper fitment, wiring not matching or anything of the sort.  The Mj already had a conversion done prior to this undertaking, as it currently sits there is a 91 YJ 4.0 with a TF999 and NP231 that will be coming out.
Thank you in advance for any and all input.
Mike
Just come across the thread by mfpdm on XJ to MJ Rear harness wiring guide printing off now and will be going over the next couple nights beside my wiring manuals.
Any other input  much appreciated!!
Definitely going to be swapping the Hvac system over, will end up with A/C in the truck as a result too. Looking at swapping the steering column as well while I have it all apart, but do I hook up the airbags from the 96 Cherokee?
Strokermjcomanche, when you can yes a pic or two would be great!
onlyinajeep726, have been reading your thread as well, nice work young man!
neohic, the cruise will be on my list of things to get working once swap is done and running proper.
Just remember, if you swap the whole column in, You have to run the brake light switch through your multifunction switch connector in the column.  Otherwise you won't have brake lights that work
Thank you for reminding me, I remember reading that on another thread somewhere. :D
Yea, There's a thread in the DIY sub-forum iirc. It has pretty much all the info needed for the wiring but doesnt include a column swap, Not sure if 95/96 are the same column, But i posted how to wire the 95 column in a later page in that thread.
