onlyinajeep726 Posted April 19, 2014 Share Posted April 19, 2014 Well, I think I've hit yet another snag in the XJ. Had the head pulled three weeks ago for head work... guy discovered a fault in the casting, so another head is in the works. In the mean time, did a little snooping over the block. Found this hole in the front of the block, beside #1 cylinder. Hole goes right into where the timing chain area is. It's jagged looking and doesn't look to me like it's supposed to be there, but I don't really know the inside of these engines. Is this supposed to be there or is this block toasted? Please tell me that this block is not FUBARed... I've already had a hard enough with this engine mess... Link to comment Share on other sites More sharing options...
cruiser54 Posted April 19, 2014 Share Posted April 19, 2014 Got a shot from the timing chain area? Link to comment Share on other sites More sharing options...
Wrz Posted April 19, 2014 Share Posted April 19, 2014 I saw similar ones in my block that had 51k on it, mine was towards the back of the head. Put a recon head on it and runs great as it should Hope that helps some Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 19, 2014 Author Share Posted April 19, 2014 On 4/19/2014 at 1:04 AM, cruiser54 said: Got a shot from the timing chain area? I do not, unfortunately. The block is still in the engine bay and harmonic balancer still attached to the crank. I know oil circulates into the timing chain area, but what I'm not sure of is how oil circulates through the rest of the block. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 19, 2014 Share Posted April 19, 2014 Too late now for me to dig around in my shed and look at an old block. I'm thinking it's normal. Don't lose any sleep over it. Link to comment Share on other sites More sharing options...
91Pioneer Posted April 19, 2014 Share Posted April 19, 2014 I don't know if that's normal or not, but as long as oil and coolant aren't mixing you should be fine. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 19, 2014 Share Posted April 19, 2014 It's normal to have jagged edges on the oil return galleys Link to comment Share on other sites More sharing options...
cruiser54 Posted April 19, 2014 Share Posted April 19, 2014 On 4/19/2014 at 3:41 AM, JeepcoMJ said: It's normal to have jagged edges on the oil return galleys I think he's seeing the upper jagged edge of the casting that runs down to the timing gears, don't you? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 19, 2014 Share Posted April 19, 2014 I just went out to the shed and verified it. Oil runs from the lifter area down on to the timing chain and gears. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 19, 2014 Author Share Posted April 19, 2014 Thanks everyone!! By the way, my head should be here Monday, then the ol' girl can be back on the road soon. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 20, 2014 Share Posted April 20, 2014 On 4/19/2014 at 1:15 PM, cruiser54 said: I think he's seeing the upper jagged edge of the casting that runs down to the timing gears, don't you? On 4/19/2014 at 1:42 PM, cruiser54 said: I just went out to the shed and verified it. Oil runs from the lifter area down on to the timing chain and gears. On 4/19/2014 at 3:41 AM, JeepcoMJ said: It's normal to have jagged edges on the oil return galleys Like I said. Maybe some clarification is necessary. The block is cast iron. With all of the machined bearing surfaces, something as trivial as the gravity oil return passages is simply punched out, and the debris removed. That is why the jagged edges are there. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 20, 2014 Author Share Posted April 20, 2014 Well, as long as that's the case, then I'm fine with that. Just wanted to make sure it wasn't an indication of a major problem. Link to comment Share on other sites More sharing options...
