I want to do a SOA rear lift, I was wondering how much this would cost and a detailed way of doing it yourself. Are there any websites where I could buy the SOA for the D35?
Not to thread hijack...
If I were to do an soa or spring under lift (with new axle)
How many degrees does the pinion have to be to be sure you be setting the right pinion angle?
(If I said that right)
You do not tilt the axle up for our kind of rear drive shafts. For drive shafts with one u-joint at each end you want the pinion yoke and the transfer case out pout to be parallel to each other. In other words they should be at the same angle. Double carden/CV type shafts with dual u-joints on one end require the pinion yoke to be raised.
Some people dial the rear pinion done just a tad so that it rides correctly under power when the front of the axle gets lifted.
what are you doing for the front of the truck?
Ditch the $hitty5 and pick up a 8.25 at least...
Indeed... or an 8.8 from a late 90's Explorer, or a 2wd Taco rear, or a D44. Heck, If I'm taking the time to cut and weld, I'm throwing another axle in.
Omo it seems to me like why not just wait and do it all at once then to do it mulitple times...why waste money on a crappy5... Why not get your good axle, which will probably have a better gear ratio anyways then spend the money you saved on other things...
