Renix Dead Spot And Idiling Low
  • Replies 176
Nothing noticeable or extreme. Just some air movement due to the rockers moving.
I have also noticed that right after a fill up, the truck revs up good after the first start up, and then settles down to a good idle. But after awhile of driving it goes back to fluctuating at idle. And yes I have replaced my gas cap. I don't know if right after filling up would cause anything to run better for some reason.
Well after a long drive today, I noticed the how the truck idles can vary. Sometimes at a stop the truck will idle pretty good and other times the rpms will jump around a bit and can feel a rough idle. The rough idle is not terrible like it is going to stale but defiantly noticeable.
Still havent been able to find a snap-on scanner but I have played with the air bleed screw some more and she seems to be running really good now! No more low idle and the idle is clean without jumping around. :rotfl2:
Thanks for all the help! I have done about everything to fix a rough idle and I hope this becomes a good reference for how to fix your idle in the future. It is a very long thread though! :thumbsup:
  • 5 months later...
Now that you've got yours sorted out, maybe I'll swing by and you can give me hand with mine! lol
And messing with that screw is certainly not a starting point.....
