Hello all. Like a lot of folks on here, I've been contemplating a 4wd swap in my 'Manche. Initially, I wanted to perform a straightforward AX4-AX5 swap. My plan was to rebuild the AX5, keep the 4 banger, not go above 31's, and drive like a granmpa (I usually do, anyway). This should give me at least a few years of use. Unfortunately, the AX5's are extremely rara around here. Apparently, nobody in West Texas ever liked the 2.5 Jeeps. I did get my paws on a Dakota bellhousing for the AX15 conversion, and am currently hunting down a 5 speed out of an XJ. I HAVE found a few YJ and TJ AX's, so that may be an option, after some mods. My question is, what do I need, aside from the tranny, clutch, and bellhousing, to perform the swap? Also, if I'm using a bellhousing from a 2.5 Dakota and an AX15, why do I need a clutch out of an 84 Camaro with a 4 banger? Couldnt I just use a Dakota clutch?
IIRC the splines on the input shaft are different on the Dakota trans so the clutch won't swap.
You will also need to figure out a pilot bearing but thats gonna depend on what AX15 you end up with.
I wouldnt pass on a good wrangler AX15, you can either run it clocked up or spend 20 minutes and reclock it.
It is higher then an MJ/XJ. The transmissions are the same though, the difference is which set of holes got drilled. Everything should be there for the other clocking, just need to drill the holes.
You may want to think about gearing, or never use OD. 5th gear in an AX5 is a mild 0.85:1 whereas the AX15 has a 5th gear ratio of 0.79:1. A 4 cylinder with stock gearing will have trouble with that ratio. Add bigger tires and it will only be usable when heading downhill.
Or swap gears and countershaft from a Toyota R151 into the AX15. Little deeper 1st gear, 0.83 5th gear. 2nd through 4th and reverse are the same.
Another thing to consider is the Dakota bellhousing is setup for an external slave, if you end up with a pre 94 internal slave AX15 you will also need a new front bearing retainer to convert the trans to external slave.
They are about $90 unless you can find a used one.
Would a 95 AX15 XJ be a good donar for the 1988 2.5L AX4 swap? Like the OP, just picked up a Dakato bell housing for the beginnings of a tranny upgrade. Also, why not just use the Jeep XJ clutch, pressure plate and flywheel if the AX15 is from an XJ? Do they not mate up with the 2.5L tailstock?
don't forget the AX-15 crossmember.  If memory serves me, it's the one that's different from the rest. :dunno:
Interesting, ^^^ I never thought the C-member would be different. You know what happens when you assume! Y'all think the AX4 and AX5 crossmembers are different?
Yes, they are.  You will also need the shift linkage parts from the AX15 donor.....the part that attaches to the tranny tunnel, the bracket that attaches to the tranny, and the rod that attaches to the mode lever on the TC.  All of these are specific to the AX15.
Jeff
within the same year/model, the AX-4 and AX-5 are identical in every way except for the 5th gear.  and a 5 added to the stickshift knob :D
