Chrysler Vin Check - Jy Find - Is Everything I Know A Lie!?
Automan2164
Was wondering if one of our resident Chryco employees could run a VIN for me. I ran across an XJ in the yard that had the Up Country Suspension Group decals in the back window and was curious whether or not the rear end would be a limited slip worth grabbing (Or having them grab). Kinda curious if if would be as serious as gear also, although I highly doubt it.
1J4FJ78S2VL589798
Also, this one is stuck in the mud, so I can't see much. Up Country also includes what else? Skids? Hooks?
Rob
Ok... So I did stop by the dealer before going out there, and I didn't get any information. He didn't even pull up the build sheet, and just gave me a "Doesn't tell me". Usually they are pretty helpful. Today, not so much... But what is really hard to figure out is the back story here. I went back to grab what I was going to assume would be the skids, limited slip, tow hooks... And found none of that. I also took a closer look into the "Limited" aspect of it. This is where I get lost. As far as I knew, '97 did not have a limited offering. As I understood it, the "Country" was still burrito supreme until '98 when the Limited made a comeback. The interior was the mist gray, but was cloth. Interesting enough though was that the door panels had a cloth insert that matched the seat, and woodgrain like a limited. So there is that. I also was confused by the "Upcountry Package" as I thought it was a full boat of skids, hooks, and suspension... But the skids and hooks were MIA, and didn't look to ever have been on. No marks or anything.
It looks like whomever had this had it pretty set up at some point, as it had a car phone (Remnants under the rear seat), the nicer sound system (Tweeters behind the mirror were already gone, but the wires to them were lopped off), rear spoiler (Assuming so from the rubber nuts in the hatch), vent visor impressions remaining, and an XJ Mopar storage box in the back. I know the storage couldn't have been for this, as it was originally a tan box that was painted to match.
The interesting thing about the box was the back was cut out of it, and the back of the panel in the XJ was cut out. I tried my best to guess what they might have been doing with the cut out, but nothing really stuck out other than 3 butt connectored wires behind the panel. Anyone have any guesses?
Pics of the Jeep:
So did '97 have Limiteds? Any guesses on the rest of this conundrum?
Rob :dunno:
Standard Equipment
Code
Description
Code
Description
Code
Description
APAS
Monotone Paint
BAUS
117 Amp Alternator
BCDS
500 Amp Maintenance Free Battery
BGAS
Power Front Disc/Rear Drum Brakes
CDBS
Reclining Front Seats
CFMS
Rear Fold w/Removable Cushion Seat
CGGS
Traveling Inboard Seat Belt Buckle
CGWS
Next Generation Front Air Bags**
CKAS
Carpets - Floor and Cargo Area
CKNS
Cargo Compartment Carpet
CKTS
Cargo Tie Down Loops
CKXS
Plastic Liftgate Trim Panel
CSRS
Passenger Assist Handles
CSSS
Lift Gate Assist Handle
CUFS
Full Length Floor Console
DGSS
4-Speed Automatic AW4 Transmission
DHNS
Command-Trac Part Time 4WD System
DJHS
Dana M30/181MM Front Axle
DRAS
Corporate 8.25 Rear Axle
GBBS
Tinted Windshield Glass
GCBS
Front Door Tinted Glass
GNAS
Rear View Day/Night Mirror
HGDS
Deluxe Insulation Group
JCDS
100 MPH Primary Speedometer
JHAS
Var Intermittent Windshield Wipers
JJAS
Cigar Lighter
JJBS
Dual Note Electric Horns
JJJS
12V Auxiliary Power Outlet
KGPS
DESCRIPTION NOT AVAILABLE
KRPS
KTPS
K3CS
LAJS
Headlamps On Warning Chimes
LBCS
Glove Box Lamp
LMAS
Halogen Headlamps
LPSS
CHMSL Lamp
MCAS
Front Bumper Guards
MHAS
Black Windshield Moldings
MMCS
Rear Qtr Solid Window Insert
MMGS
Belt Moldings
MMKS
Body Color Drip Trough Molding
MNAS
Black Door Handles
NBKS
EVAP Control System
NFAS
20 Gallon Fuel Tank
QCJS
Dark Blue Pearl Coat
SBAS
Power Steering
SDAS
Normal Duty Suspension
SHAS
Front Stabilizer Bar
SHCS
Rear Stabilizer Bar
TBLS
Inside Mounted Spare Tire
XCYS
Delete Remote Start System
XJFS
Tethered Fuel Filler Cap
YAAS
Build To U.S. Mkt. Specifications
Z5BS
Payload Rating - 1800#
1AAS
U.S. Dealer Retail
155S
Zone 55-Milwaukee
5ITS
XK-Vehicle Family
5IWS
JS-Vehicle Family
650S
Wisconsin State Code
950S
Optional Equipment
Code
Description
Code
Description
Code
Description
*XJ
Cloth Low-back Bucket Seats
-C3
ADAP
Light Group
AHT
Trailer Tow Group
ARXP
Country Decor Group
AWHP
Power Equipment Group
A20P
CACP
Low Back Bucket Seats
CBVP
Cloth Door Trim Panel w/Map Pocket
CLEP
Front Rear Floor Mats
CSAP
Spare Tire Cover
DGB
All 4-Speed Automatic Transmissions
DHAP
Lock-Up Torque Converter
DHSP
Floor Mount Automatic Shift Lever
DMDP
3.55 Rear Axle Ratio
EAAC
All Engines
ERH
4.0L I6 Power Tech Engine
GAL
Deep Tint Sunscreen Glass
GEEP
Deep Tint Sunscreen Liftgate Glass
GFA
Rear Window Defroster
GNCP
Sun Visors w/Illum Vanity Mirrors
GTZP
Power Mirrors, Fold-Away
GVBC
All Vehicles W/Power Mirrors
GXMP
Remote Keyless Entry
HAAP
Air Conditioning
JAYP
Instrument Cluster w/Tach
JBGP
Instrument Panel Woodgrain Bezel
JHBP
Rear Window Wiper/Washer
JPAP
Power Windows
JPBP
Power Locks
JPS
Power 6-Way Driver Seat
KBSP
KCPP
KYPP
K2CP
LBBP
Courtesy Lamps
LCDP
Map/Dome Reading Lamps
LDAP
Underhood Lamp
LDBP
Cargo Compartment Lamp
LHDP
Headlamp Off Time Delay
LNJ
Fog Lamps
MBPP
Body Color Front Bumper
MBQP
Body Color Rear Bumper w/Step Pads
MDAP
Front License Plate Bracket
MFKP
Body Color Grille
MWGP
Roof Rack
NAA
Federal Emissions
NHBP
Auxiliary Transmission Oil Cooler
NHMP
Speed Control
NMCP
Heavy Duty Engine Cooling
PCJ
Dark Blue
RAAC
All Radio Equipped Vehicles
RAZ
AM/FM Cassette Compact Disc Radio
RCDP
4 Speakers
RDDP
Fixed Long Mast Antenna
SCGP
Leather Wrapped Steering Wheel
SUAP
Tilt Steering Column
TBB
Full Size Spare Tire
TRVP
P225/70R15 Eagle GA OWL AS Tires
TZAP
Goodyear Brand Tires
WJ7P
15X7.0 Luxury Aluminum Wheels
WKBP
Matching Spare Wheel
WLZC
All Aluminum Wheels
YGFA
8 Additional Gallons of Gas
ZFJP
Spring - Left Front
ZFUP
Spring - Left Rear
ZUJP
Spring - Right Front
ZUUP
Spring - Right Rear
2THA
Customer Preferred Package 2TH
26H
Customer Preferred Package 26H
3J3A
No Charge Air Conditioning
3VUA
Customer Preferred Discount
4X6A
Wisconsin Act-13 Recovery
Talk about a jumbled mess. Doesn't appear very helpful either from scanning through it, all I really noticed was tow group and country decor group. It also says something about each of the springs at the end there, but nothing about skids, hooks, or most other options the limited/UC packages had.
Thanks fellas!
I see the 'ARXP Country Decor Group' which somewhat confirms my original thought that maybe someone swapped the country decals out for the limited ones... I see mention of the 8.25 and 3.55 gears, but nothing as far as a limited slip. I do see all 4 aluminum rims and a matching spare listed though... It only had a convenience spare in it at the yard, and looked like it had only had that for awhile judging by the carpet impression on the rear wheel well.
Only real way to know about the limited slip will probably be to have them pick it up so I can get to the diff cover... Or bring a jack and do it myself.
Rob :hmm:
Its 75 degrees down here Rob.  Just write that one off so you don't have to lay in the ice sludge......send me a requisition and I'll get you what you want all the while wearing my shorts and Birkenstocks.
Just kidding, I really don't wear no damn hippie birkenstocks.  But since its spring now I'm in sandals and shorts instead of my winter cowboy ariats and carhartts.
Thanks fellas!
Rob :hmm:
Did the sticker on the firewall match the dash VIN Rob?
If it didn't, that would explain a lot.
I used to own a '95 grand Cherokee Orvis.  I thought upcountry meant LSD, 1 3/4' lift and special shocks.  Orvis came with skids and tow hooks but up country didn't guarantee it.   Dang it Rob.  I wish you didn't ask that question.  I sure wish I didn't trade that thing.  :(
When I was in the back panel, there was an assembly VIN tag sticker on the body that matches everything else.
I'm confused by the whole thing. On another note... I too wish I'd have kept my ZJ... I underestimated how nice the ride and comfort of it was until I got back into an XJ... Boy do I miss that ZJ.
Rob
Rob
VIN matches? ok then :)
Any chance it was an early production model?
I haven't dug out the 97' book yet, but being a transition year, who knows
And as far as ZJs go....
 I never really liked ours (Black 96' 4.0L),
 but it was the most rust free vehicle I ever owned.
I have no idea why it was so immune to rust.
 When the trans went @90k miles, I gave it to a neighbor for his son (with a used, working trans in the back waiting to go in).
He drove it for 6 months, then junked it when the 2nd trans went.
Last time I ever saw it, he had shinned up the dulled black paint, cleaned up the 31" BFG AT's, and it looked better than it ever did the whole time I owned it :(
1997 Sales Consultant Product Guide lists
New for 1997;
Carryover from 1996
1996 Cherokee Classic model added
1997 Jeep Cherokee to be introduced mid-model year
but even for the 1996's it doesn't list a limited,
just the SE, Sport, Classic & Country
There is a 1997 Cherokee section,
but it just says "A revised edition of the famous Jeep Cherokee is due to arrive at dealerships in early 1997,
bla bla bla watch for new releases in the first quarter of 1997.
The Jeep and Eagle Product Information book  (November 1996) does break down the 97' Cherokee
Under What's new for 1997
it says New Country models feature body color bla bla bla
It only lists SE, Sport and Country as being available
weird
For the Up Country Suspension Group,
it lists the 3 skids, full size spare 225/75's tow hooks trans cooler shocks, rear sway delete and the LSD
since that one had none of.that stuff,
I wonder if it had the sway delete?!?
Guy probably had a body shop buddy redecal the whole thing as an UpCountry Limited I guess?!
Hey Rob,
Going off of the 4.0 Litre badge on the liftgate, it looks to be a 2000 or a 2001 XJ, not a 97, unless someone swapped liftgates. Thought it may be helpful.
Seth
But it has the full roof rack,
 IIRC that means 1997 or 1998 (I think)
I used to remember all this stuff, but it's fading fast.
Hey Rob,
Seth
The 2001 my Dad owned for awhile had a roof rack just like that one. It was just a Classic. EDIT: Found some pics, it did stop before getting to the front doors. Must have been thinking of one of the million other SUVs he went through there for awhile.
When I was looking for my last XJ (13 years ago now, wow time flies...),
 the short rack was one way to tell the difference between an 97/98, and a 99+ (again, IIRC on the years).
I don't believe 01's have their roof racks all the way over the drivers seat, but I'm open to the possibility of being wrong.
My 00 XJ didn't have the full rack up top. It stopped above the rear doors.
EDIT: I found this by Googling the VIN
1997 Jeep Cherokee - VIN 1J4FJ78S2VL589798
There are 1 records stating that this vehicle is for sale at auto auctions. To get more information order the Full Report.
Auction sales: Sale Date: Jan 6, 2014
VIN: 1J4FJ78S2VL589798
Year: 1997
Make: Jeep
Model: Cherokee
Style/Body: SPORT UTILITY 4-DR
Engine: 4.0L L6 OHV 12V
Country of Assembly: UNITED STATES
  • 3 months later...
I bring thee back from the dead!
Well curiosity killed the cat. I've been watching this thing move around the yard and get picked over, but it is still there. The other day I noticed that it no longer had any drums on it, so I could give the axles a spin (still on the ground in the mud, but now it was resting on the plates).
I bent down and gave the axle a spin, and to my surprise, the driveshaft started banging around... Hmm... That's a good sign. Went back up and asked if they could raise it and let me pull the cover to check. He told me they only really do that when they are selling the part. I went back out there to see if I could drag up an axle tag or something. When I went back I noticed how much lower the back was, and then realized that the leafs were gone. Now this is easy picking... Only thing left holding it in were the parking cables, shocks, and the brake line. I scrounged around for a jack out of another car, found an HD scissor jack out of a truck. Got it up a foot, pulled the shocks, and cut the brake hose. I didn't have anything to cut the cables. It was enough to slide it partially out and pull the cover... Jackpot! A short trip back down the road to work for some cable cutters and it was mine.
10468094_689774361060054_583186934325213
10402021_689774374393386_376656782037567
10411431_689774401060050_315561096085977
$133 and it was in the back of my XJ. I already bought all new brakes, drums, shoes, and hardware for the current 8.25 but after installing the sway bar I noticed both axle seals were leaking, and the pinion seal was shot. I think the game plan switched, and this axle will be getting the new brakes and some seals for an upgrade instead of a plain repair.
Rob :rock on:
