54bobby Posted February 26, 2014 Share Posted February 26, 2014 are they available new or do I need to track down a used one? 87 2.5 ok found some on fleabay. will the 4.0 fit my 2.5? Link to comment Share on other sites More sharing options...
yxmj Posted February 26, 2014 Share Posted February 26, 2014 You could have a look at any shroud from for a 2.5 from a XJ, YJ or TJ The 2.5 shroud is different that the 4L Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 26, 2014 Share Posted February 26, 2014 I have one for you, $20 plus shipping. Good shape. jeepmurphy@gmail.com Link to comment Share on other sites More sharing options...
54bobby Posted February 27, 2014 Author Share Posted February 27, 2014 pm'd Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 27, 2014 Share Posted February 27, 2014 Just FYI... the 2.5 and 2.8 radiators are the same but the shrouds are different due to water pump location. Link to comment Share on other sites More sharing options...
randomguy310 Posted February 27, 2014 Share Posted February 27, 2014 the shroud on a tj yj I think are very different then xj mj Link to comment Share on other sites More sharing options...
yxmj Posted February 27, 2014 Share Posted February 27, 2014 the shroud on a tj yj I think are very different then xj mj Not on the 2.5......I am running a yj one right now Link to comment Share on other sites More sharing options...
randomguy310 Posted June 5, 2014 Share Posted June 5, 2014 my whole point was that the 4.0L didn't come with out a elect fan.. they are designed to have them they will not have enough cooling.. that was my point.. do some research and you will see from the factory all had elect fan.. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 5, 2014 Share Posted June 5, 2014 my whole point was that the 4.0L didn't come with out a elect fan.. they are designed to have them they will not have enough cooling.. that was my point.. do some research and you will see from the factory all had elect fan.. Your whole point is wrong. You do some research - if no A/C option was selected - NO electric fan included with the 4.0. I'm sure there were exceptions available from the dealership as there always are, but here is an excerpt from the 1988 MJ factory spec sheet stating the A/C option content. That's why it's called an auxiliary electric fan - not standard equipment on all 4.0 MJ models. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 5, 2014 Share Posted June 5, 2014 Applause Hornbrod. Can't stand when people post flat out incorrect info, so thanks for correcting. Also, you can NOT associate 4.0 with 2.5 cooling. The 87 and up 2.5 used an adapter mount to put a 2.5 radiator onto a 4.0 core support, but nothing other than the front crossmember and header panel support are even close to the same. Link to comment Share on other sites More sharing options...
91Pioneer Posted June 5, 2014 Share Posted June 5, 2014 I have an '88 4.0L without A/C and it has the electric fan. Link to comment Share on other sites More sharing options...
