Locking Diff?
  • Replies 54
If it’s allowing different wheel speeds across the axle in the “locked” mode, then it’s not a locker. There’s different kinds of auto-locker, and some of them do require a speed differential to lock in, while others operate more like a spool that disengages under low load. I’m sure there’s other varieties out there as well... but if they allow for slip between the axle shafts, then it’s a limited-slip diff, not a locker.
On 9/3/2020 at 10:34 PM, gogmorgo said:
A limited slip alters the torque bias. Depending on the model, a Truetrac could be as much as 3.5:1. This means that it’s going to bind up so that it pushes 3.5 times as much torque onto a “stationary” wheel as it does on the free-spinning wheel.
"as much as 3.x..." or "up to 3.x..."
I see this language often and then my understanding starts getting muddled.  In a Torsen style differential, is the torque biasing capability progressive?
Or does it try to transfer the full 3.x all the time?
