Getting ready to order a set of BIlsteins 4600 series.
The site that I want to order from lists the rears as- bil-24-002608
According to another site those fit-
  • 1959-1983 Jeep CJ5 - Base - USA
  • 1975-1983 Jeep CJ5 - Renegade - USA
  • 1977-1980 Jeep CJ5 - GoldenEagle - USA
  • 1980-1983 Jeep CJ5 - Laredo - USA
  • 1982-1983 Jeep CJ5 - Limited - USA
  • 1959-1975 Jeep CJ6 - Base - USA
  • 1976-1986 Jeep CJ7 - Base - USA
  • 1976-1986 Jeep CJ7 - Renegade - USA
  • 1977-1979 Jeep CJ7 - GoldenEagle - USA
  • 1980 Jeep CJ7 - GoldenHawk
  • 1980 Jeep CJ7 - GoldenHawk - USA
  • 1982-1983 Jeep CJ7 - Limited - USA
  • 1980-1986 Jeep CJ7 - Laredo
  • 1980-1986 Jeep CJ7 - Laredo - USA
  • 1966-1974 Jeep DJ5 - Base - USA
  • 1965-1983 Jeep DJ5 - Base
  • 1966-1968 Jeep DJ6 - Base - USA
  • 1965-1968 Jeep DJ6 - Base
- See more at: http://www.stillen.com/product/shocks/4600-series-shock--46mm-monotube-shock-rear-5983-jeep-cj5-596075-cj6-7686-cj7-6674-dj5-6668-dj6-93843.html#sthash.mx0qrBPw.dpuf
And according to Hornbird's list-
What do you guys think?
Do you have a lift or is it normal ride height because I have bilstein 46oo series on the front and rear of my Comanche ( normal height) and still have the boxes with part numbers
If you would post the part #s I'd appreciate it.
I have a feeling he stocks the CJs and they may be close.
Yeah, stock hight for me.
Thanks.
Hornbird's??
It's Hornbrod mate. But I've been called worse.   :yes:
Sorry, don't know why that's what I see every time you post.
What does Hornbrod mean?
And tell me how you like your ride.
I had Bilsteins on my Ranger but it might be apple to oranges comparison......I just don't what to be disappointed I guess.
Long story short: I looked up the Monroe part number for the rear shock at the part store I worked at then I looked through all the applications until I found something that had factory bilsteins as shocks . It was a ranger ( I believe early 2000s if iirc) checked the extended and closed lengths ( spot on ) except when I got it the lower bushings for the rear shocks had a steel sleeve in them so I got a set of bushings and swapped them out . The fronts are easy look up the same year Cherokee( xj ) front number is 24-010450 and rears are 24-196277
  • 7 years later...
