Jeep Driver Posted February 3, 2014 Share Posted February 3, 2014 I lost idle.....high idle. What is the part at the 6oclock position? When unplugged the idle returns to normal. Link to comment Share on other sites More sharing options...
AeroNautical Posted February 3, 2014 Share Posted February 3, 2014 Is that the newer HO MAP sensor? If so, sounds like it's time for a new one. Link to comment Share on other sites More sharing options...
87Warrior Posted February 3, 2014 Share Posted February 3, 2014 Yep, that is the MAP. Check for the small vacuum fitting on the bottom. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted February 3, 2014 Share Posted February 3, 2014 Not fishing for help, or to help the topic, but for personal knowledge, whats this come off of with the MAP on the TB?HO? Grand? ? Link to comment Share on other sites More sharing options...
AeroNautical Posted February 4, 2014 Share Posted February 4, 2014 Not fishing for help, or to help the topic, but for personal knowledge, whats this come off of with the MAP on the TB? HO? Grand? ? It is HO, and I have never seen this on a HO XJ, so my money is with a TJ or ZJ. Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 4, 2014 Author Share Posted February 4, 2014 This is an XJ. Please see my other thread. Link to comment Share on other sites More sharing options...
oldseddie Posted February 4, 2014 Share Posted February 4, 2014 97-01 the map sensor moved to the throttle body. Link to comment Share on other sites More sharing options...
Rockfrog Posted February 4, 2014 Share Posted February 4, 2014 x2 my 2000 xj is exactly like that. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 4, 2014 Share Posted February 4, 2014 97-01 the map sensor moved to the throttle body. Actually it was in 1996, the first year of OBD2. In 1997 the MAP sensor changed (different connector but functionally the same). I'm in the process of hooking up a 96 throttle body mounted MAP on my 91 to get rid of the long vacuum line from the firewall mounted MAP to the intake manifold. Will post up later if all works as I expect it to. Link to comment Share on other sites More sharing options...
JoeLAW Posted May 15, 2014 Share Posted May 15, 2014 Hornbrod, any luck with the transfering of the MAP? 97-01 the map sensor moved to the throttle body. Actually it was in 1996, the first year of OBD2. In 1997 the MAP sensor changed (different connector but functionally the same). I'm in the process of hooking up a 96 throttle body mounted MAP on my 91 to get rid of the long vacuum line from the firewall mounted MAP to the intake manifold. Will post up later if all works as I expect it to. Hornbrod, any luck with the transfering of the MAP? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 15, 2014 Share Posted May 15, 2014 Yep - works fine. http://comancheclub.com/topic/41929-installing-a-1996-throttle-body-mounted-m-a-p-sensor/ Link to comment Share on other sites More sharing options...
JoeLAW Posted May 15, 2014 Share Posted May 15, 2014 Yep - works fine. http://comancheclub.com/topic/41929-installing-a-1996-throttle-body-mounted-m-a-p-sensor/ Awesome Thanks! Link to comment Share on other sites More sharing options...
