88whitemanche Posted January 19, 2014 Share Posted January 19, 2014 What's up guys I'm in the process of accumulating parts for the single axle shaft upgrade to my cad dana 30... I got the bigger u-joint axle shafts through a trade, just bought a new solid diff cover... I know I need the new inner seal part number to fit the new shaft does any one have it? Also where can I get a block off plate besides going to rustys offroad website.... Link to comment Share on other sites More sharing options...
skidoo_j Posted January 19, 2014 Share Posted January 19, 2014 Yukon gear sells a set. It includes all known seals and a block off plate. ya w391470-kit 21364 upc code: 883584213642 I'm sure you can find it cheaper, or make one. http://www.summitracing.com/parts/yga-21364 Just an fyi I researched all the possible seals and bought them all. A buddy of mine had that kit, I made my own plate, but the seal i needed was $20. Seals I found in various forums more ** means mentioned more times. I don't recall which i ended up using cr11800 **NOS 11343 NOS11777 ** 40576S / NOS 11771 NOS 18050 / 203006S NOS 11899 Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 19, 2014 Share Posted January 19, 2014 I would have just swapped a later D30.......but that's just me. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 19, 2014 Share Posted January 19, 2014 I would have just swapped a later D30.......but that's just me. That's that I did, only i went with CV joints instead of the larger U-joints. Link to comment Share on other sites More sharing options...
mvusse Posted January 20, 2014 Share Posted January 20, 2014 Seal part number in first post of thread linked in my signature. Block off plate can be made with a piece of 1/8 steel, a jig saw, a drill and using the cad housing as a pattern. Link to comment Share on other sites More sharing options...
88whitemanche Posted January 22, 2014 Author Share Posted January 22, 2014 I would have just swapped a later D30.......but that's just me. I wish it were that easy to find a dana 30 with 4.10 gears in the jy from a newer cherokee if 4cyl 4wd were dime a dozen and not regearing. but the axle shafts were the best option to upgrade my front axle instead waiting months or years to accommodate a 4.10 axle I would do it...but the cheapest option for me is the shafts Link to comment Share on other sites More sharing options...
